Home » Archived » BIRT » Problems with Oracle JDBC data source
Problems with Oracle JDBC data source [message #43582] Tue, 07 June 2005 02:46 Go to next message
Originally posted by: juergen.schwarz.gefasoft.de
I'm using BIRT 1.0 and cerated a datasource to an Oracle 9 database and
a new record set for a table in that DB.
In the record set settings box in BIRT everything works, I can see and
select the table columns, even the preview of the records is fine.
But in the report where I want to use these records, the preview does
not work but generates the following error message:
There are errors on the report page:Error1:Die Verbindung kann fьr
Treiber (org.eclipse.birt.report.data.oda.jdbc) nicht geцffnet
werden.Cannot load JDBC Driver class: [oracle.jdbc.OracleDriver]. Cannot
Sorry, BIRT display in German on my system.
Any help what the cause for this may be?
Juergen
Re: Problems with Oracle JDBC data source [message #43779 is a reply to message #43582] Tue, 07 June 2005 12:43 Go to previous messageGo to next message
The most likely cause is that the JDBC driver has not been installed in
the viewer plugin directory. Check the following directory. Do you see
your Oracle JDBC driver there? If not you will need to manually copy that
driver's JAR files to this location for report preview to work:
\eclipse\plugins\org.eclipse.birt.report.viewer_1.0.0\birt\W EB-INF\plugins\org.eclipse.birt.report.data.oda.jdbc\drivers
For more information about installing JDBC drivers, check the BIRT FAQ
page. If this does not solve your problem, you should open a Bugzilla
report so a BIRT developer can investigate.
Gary Xue
BIRT Committer - Data Engine project
Re: Problems with Oracle JDBC data source [message #44277 is a reply to message #43779] Wed, 08 June 2005 01:34 Go to previous message
Great this works!
But the file was not there, I really had to copy it. Somehow it was'n
copie automatically.
Juergen
> that driver's JAR files to this location for report preview to work:
> Gary Xue
Previous Topic:How to update/add JBDC Driver ?
Next Topic:problem with chart legend
Current Time: Sun Nov 09 09:43:08 EST 2025
Powered by FUDForum. Page generated in 0.23911 seconds
