Home » Eclipse Projects » SWTBot » Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests
Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #39077] Tue, 16 June 2009 13:23 Go to next message
As the title states I am unable to run any of my SWTBot tests since
upgrading from SWTBot 204 to 348. I cannot get updates often as my
company restricts web access. This is also being written on a different
machine which has internet access (don't think they want us playing while
at work). Anyways when I attempt to run the SWTBot test it errors out
right away with the following.
An internal error occurred during: "Launch SWTBot".
org/eclipse/pde/internal/core/util/CoreUtility
Also getting a NoClassDefFoundError is the above class (CoreUtility).
I am a tester so if this is something that is easy to figure out I am
sorry.
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #39115 is a reply to message #39077] Tue, 16 June 2009 13:40 Go to previous messageGo to next message
What version of eclipse are you on ? Did you download swtbot from the
correct update site ? There's an update site for 3.4(ganymede) and
another for 3.5(galileo).
Also you may find this bug relevant:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=274083
If all else fails, file a bug with the version numbers of eclipse,
swtbot and the platform you are working on.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
> while at work). Anyways when I attempt to run the SWTBot test it errors
> out right away with the following.
> sorry.
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #39176 is a reply to message #39115] Tue, 16 June 2009 15:47 Go to previous messageGo to next message
I'm having the same problem. I'm using Eclipse 3.4.1 and SWTBoT 2.0.348.
It works well until I upgraded to latest version.
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #39330 is a reply to message #39115] Wed, 17 June 2009 07:35 Go to previous messageGo to next message
I believe we are on Eclipse 3.4 build 2000. I believe the problem is that
we need to update our Eclipse. When I looked for the Core Utility in the
plug-in view (under show view) that plugin did not exist. I am going to
try and see if our SA will allow us to upgrade our eclipse as our
development machines are not connected to the internet.
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #39791 is a reply to message #39176] Fri, 19 June 2009 18:41 Go to previous messageGo to next message
Same problem here, Eclipse 3.4.2 and SWTBot 2.0.348.
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #39821 is a reply to message #39791] Mon, 22 June 2009 05:04 Go to previous messageGo to next message
Originally posted by: h.grosse-plankermann.iks-gmbh.com
Same for me, Eclipse 3.4.2 and SWTBot 2.0.348 using the Ganymede Update
Site.
Checked E3.5 RC4 using Galileo Update Site (which also serves SWTBot
2.0.348). Worked l
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #39852 is a reply to message #39821] Mon, 22 June 2009 09:07 Go to previous messageGo to next message
There's two versions of SWTBot for two versions of eclipse to compensate
for changes in API in eclipse and junit. You need to be using the
correct update site or things will not work as expected and you'll get
method not found errors.
Ketan
> Site.
> 2.0.348). Worked líke a charme!
> Perhaps the version optimized for 3.5 leaked to the 3.4 Update site?
> Holger
> "Konstantine Prevas"<kprevas@guidewire.com> schrieb im Newsbeitrag
> news:3f2d97d2dbb4e65b6610434c713579de$1@www.eclipse.org...
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #39882 is a reply to message #39852] Mon, 22 June 2009 09:18 Go to previous messageGo to next message
I am using the Ganymede Update Site for my Eclipse 3.4.2
( http://download.eclipse.org/technology/swtbot/ganymede/dev-b uild/update-site)
and I am recieving the exceptions mentioned earlier in this thread:
The distribution I am using:
http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/ganymede/SR2/eclipse-rcp-ganymede-S R2-win32.zip
Any idea what could be wrong here?
Holger
"Ketan Padegaonkar" <ketanpadegaonkar@gmail.com> schrieb im Newsbeitrag
news:h1nvu3$5c0$1@build.eclipse.org...
> for changes in API in eclipse and junit. You need to be using the correct
> update site or things will not work as expected and you'll get method not
> found errors.
> Ketan
>> Site.
>> 2.0.348). Worked l
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #39914 is a reply to message #39882] Mon, 22 June 2009 11:04 Go to previous messageGo to next message
Could you open a bug and attach the complete stack trace ?
Ketan
> Regards
> Holger
> "Ketan Padegaonkar"<ketanpadegaonkar@gmail.com> schrieb im Newsbeitrag
>> found errors.
>> Ketan
>>> Site.
>>> Regards,
>>> Holger
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #39946 is a reply to message #39882] Mon, 22 June 2009 11:47 Go to previous messageGo to next message
> Regards
> Holger
>> found errors.
>> Ketan
>>> Site.
>>> Regards,
>>> Holger
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #39977 is a reply to message #39882] Mon, 22 June 2009 11:49 Go to previous messageGo to next message
I think I've found the fix. This was introduced as part of bug 268881.
I'll push out a build shortly.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=268881
Ketan
> Regards
> Holger
>> found errors.
>> Ketan
>>> Site.
>>> Regards,
>>> Holger
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #40005 is a reply to message #39077] Mon, 22 June 2009 12:43 Go to previous messageGo to next message
I've fixed this issue and pushed out a new build.
You may notice that the update takes too long, or fails midway -- the
eclipse servers are currently taking a *huge* hammering because of all
the buzz and activity happening for the new upcoming release. Please be
patient and retry again if the download fails, it took me 4 retries to
download the whole thing.
Ketan
> sorry.
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #40036 is a reply to message #39977] Mon, 22 June 2009 14:43 Go to previous messageGo to next message
Was the new build created to correct this issue yet?
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #40066 is a reply to message #40036] Mon, 22 June 2009 16:05 Go to previous messageGo to next message
Yes it has, just pull a new update.
Ketan
Re: Upgraded from build 204 to 348 and now I cannot run any SWTBot Tests [message #40163 is a reply to message #40066] Tue, 23 June 2009 05:17 Go to previous message
Works for me!
Thank you Ketan!
Holger
news:h1oodk$rqa$1@build.eclipse.org...
> Ketan
Previous Topic:test RCP application using swt/swing bridge
Next Topic:SWTWorkbenchBot#button works only on button class with style == SWT.PUSH - why?
Current Time: Wed Nov 19 20:45:10 EST 2025
Powered by FUDForum. Page generated in 0.05972 seconds
