Home » Language IDEs » PHP Development Tools (PDT) » phpActionImplementor ?
phpActionImplementor ? [message #2905] Sun, 04 March 2007 17:12 Go to next message
Hi guys,
I just wanted to point you to some incorrectness in this extension point
design. IPHPActionImplementor interface is funny, the only method is
instantiateFromExtensionPoint(), so every action should implement registry
lookup mechanism by itself... (the naming is also problematic, since action
which implements this interface is actually not an "implementor", this
action should be rather called "delegate").
Another problem is that SelectionDispatchAction must accept in its
constructor non-null IWorkbenchSite, therefore ReorgMoveAction tries to get
it
from " PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().getActivePart().getSite() "
at the moment when it is being created. If you have an initially closed
editors, and when you open one of them after PDT start you get:
org.eclipse.php.internal.ui.actions.ReorgMoveAction.<init>(ReorgMoveAction.java:39)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e
Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:157)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.php.internal.ui.actions.MoveAction.instantiateAc tionFromExtentionPoint(MoveAction.java:137)
org.eclipse.php.internal.ui.actions.MoveAction.initMoveActio n(MoveAction.java:71)
org.eclipse.php.internal.ui.actions.MoveAction.<init>(MoveAction.java:52)
I suggest to rework this extension point as follows:
1) As long as this extension point can be used only with
SelectionDispatchAction - call it with a more concrete name.
2) Change the extension super class type from SelectionDispatchAction to
other type, so it will accept IWorkbenchSite in a setter method (after
createExecutableExtension call), rather than trying to find it in a
constructor.
3) Create some factory class for such implementers, that has a method:
getSelectonDispatchActionImplementer(String targetActionId) which returns
action implementer according to the target action ID.
PS: will this extension be useful in other cases than MoveAction and
RenameAction? May be it should be "move/rename strategy extension point"?
Thanks.
Michael
Re: phpActionImplementor ? [message #3026 is a reply to message #2905] Tue, 06 March 2007 13:27 Go to previous messageGo to next message
Hi Michael,
thanks for the feedback
I made several modifications to the code and committed them.
If possible, please send this kind of feedback through the mailing list
Thanks a lot,
Eden
"Michael Spector" <spektom@gmail.com> wrote in message
news:esfg7v$hk9$1@utils.eclipse.org...
> Hi guys,
> action
> get
> it
> from
> java.lang.NullPointerException
> at
> Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> constructor.
> Thanks.
> Michael
Re: phpActionImplementor ? [message #3042 is a reply to message #3026] Tue, 06 March 2007 14:59 Go to previous message
Eden Klein wrote:
> Hi Michael,
Sorry, I've meant to send it to the mailing list... look at the letter
time - it was too late :)
Michael
Previous Topic:What ha
Next Topic:bundled eclipse version not 3.2.1
Current Time: Sat Nov 08 00:44:07 EST 2025
Powered by FUDForum. Page generated in 0.03356 seconds
