Home » Archived » Riena » Riena 1.0.M2 and required bundles vs import
Riena 1.0.M2 and required bundles vs import [message #2846] Tue, 20 May 2008 13:18 Go to next message
Originally posted by: ekkehard.gentz-software.de
common bundles like Hessian, Log4J or so which are not part of eclipse SDK,
I'm using from the SpringSource Enterprise Bundle Repository.
http://www.springsource.com/repository/app/
if I'm using
com.springsource.com.caucho-3.1.5
com.springsource.org.apache.log4j-1.2.15
this won't work with Riena, because Riena uses
'Required bundle' in MANIFEST.MF
if you would use 'Import' instead, then I could use the bundles from
SpringSource with Riena, too
ekke
Re: Riena 1.0.M2 and required bundles vs import [message #4082 is a reply to message #2846] Tue, 03 June 2008 10:29 Go to previous messageGo to next message
what do you think about this ?
should I open a bugzilla ?
ekke
Re: Riena 1.0.M2 and required bundles vs import [message #4209 is a reply to message #4082] Wed, 04 June 2008 07:55 Go to previous messageGo to next message
Sorry I didn't reply to your question in the first place.
This is a tricky one which I briefly discussed with a collegue but forget to send you about it.
Hessian is a bundle that we put in the Riena project at least currently because no other project currently uses it. So
it didnt end up in Orbit the Eclipse equivalent of the SpringSource Repository.
Up to now we have not modified the source code of hessian itself because it wasn't necessary. I am not absolutly sure
that we can always be sure that it stays that way. Another issue is the MANFEST.MF in hessian. Ours defined
Eclipse-BuddyPolicy: register which I have no idea that I can rely on that Springsource has the same.
I am also not sure why you want to use the one from SpringSource if Riena is already bringing on. Are you using other
components outside from Riena that also need hessian ? Even then 2 hessian components can coexist, ok I agree that this
is not very nice.
I am not sure if you should change all required bundle entries to import package for all externall packages. The risk is
that Riena wont run and somebody will have a hard time to find out why.
For Logging I think we could change that because if logging doesnt output anything, that is not as critical as if remote
services dont work anymore. Please add a bugzilla asking for that change.
You can also add another bugzilla for the hessian issue. Please give some more details why you prefer to use the hessian
implementation from SpringSource and how we can be sure that the manifest allows to register buddies.
Are there any performance issues when using Imports over Requires-Bundle ? Not sure.
regards
christian
> ekke
Re: Riena 1.0.M2 and required bundles vs import [message #4420 is a reply to message #4209] Wed, 04 June 2008 08:45 Go to previous message
hi christian,
thanks for making things clearer.
of course the buddy is not part of the SpringSource repository,
because it doesn't depend on equinox ;-)
so in this case we need the Riena-bundle
I think its always good to use Import where possible because
then its easier to replace a bundle.
and from my opinion its always good to use an existing bundle from a
repository (orbit or springsource or bnd) instead of creating
an own.
otherwise there can be much chaos ;-)
I'm just testing and integrating Easybeans OSGI with equinox
instead of felix. but thats only the first part.
next one is integrating this with Riena
so for common bundles like log4j, commons-xxx, hibernate, etc
I prefer to use them only one time in the whole system (my osgi server)
and so I like import, which gives enough stability in these cases
if the import is combined with a version number (if a special one is
needed)
I'll open a bugzilla for using import with logging
thx again for your detailed informations
ekke
btw: if you have read the german osgi book from gerd wütherich, chapter
5.4 - they also prefer import before require bundle
send you about it.
Repository.
> is not very nice.
Not sure.
> regards
> christian
>> ekke
Re: Riena 1.0.M2 and required bundles vs import [message #571687 is a reply to message #2846] Tue, 03 June 2008 10:29 Go to previous message
ekke
Re: Riena 1.0.M2 and required bundles vs import [message #571744 is a reply to message #4082] Wed, 04 June 2008 07:55 Go to previous message
is not very nice.
regards
christian
> ekke
Re: Riena 1.0.M2 and required bundles vs import [message #571832 is a reply to message #4209] Wed, 04 June 2008 08:45 Go to previous message
hi christian,
an own.
needed)
ekke
send you about it.
Repository.
> is not very nice.
Not sure.
> regards
> christian
>> ekke
Previous Topic:riena server outside eclipse
Next Topic:Riena Launch configuration
Current Time: Sun Nov 09 18:04:50 EST 2025
Powered by FUDForum. Page generated in 0.04495 seconds
