Home » Eclipse Projects » Dash » Help with Monkey script (IllegalArgumentException calling Eclipse API method)
Help with Monkey script (IllegalArgumentException calling Eclipse API method) [message #2799] Wed, 07 November 2007 21:12 Go to next message
Hi all, I'm working on a simple Monkey script, the intent
of which is to generate a UUID and put it on the clipboard.
I have this so far, which at first blush looks like
it should work. But line 18 blows up with an IllegalArgumentExeption.
Any thoughts?
* Menu: Gen > UUID
* Kudos: Whoever
* Key: CTRL+ALT+U
* License: EPL 1.0
function main() {
clipboard = new
Packages.org.eclipse.swt.dnd.Clipboard(Packages.org.eclipse. swt.widgets.Display.getCurrent());
transfers = java.lang.reflect.Array.newInstance(
Packages.org.eclipse.swt.dnd.Transfer, 1);
transfers[0] = Packages.org.eclipse.swt.dnd.TextTransfer.getInstance();
data = java.lang.reflect.Array.newInstance(java.lang.Object, 1);
data[0] = java.util.UUID.randomUUID();
clipboard.setContents(data, transfers); /* THIS LINE BLOWS UP */
clipboard.dispose();
Packages.org.eclipse.jface.dialogs.MessageDialog.openInforma tion(
window.getShell(),
"Your new UUID",
textData
Phil
Re: Help with Monkey script (IllegalArgumentException calling Eclipse API method) [message #2818 is a reply to message #2799] Wed, 07 November 2007 21:17 Go to previous message
Never mind, figured it out. I was putting a UUID object in
the data array instead of a String.
should be: data[0] = java.util.UUID.randomUUID().toString();
Phil
Re: Help with Monkey script (IllegalArgumentException calling Eclipse API method) [message #560462 is a reply to message #2799] Wed, 07 November 2007 21:17 Go to previous message
Phil
Previous Topic:Help with Monkey script (IllegalArgumentException calling Eclipse API method)
Next Topic:Examples, examples.
Current Time: Thu Nov 06 21:08:55 EST 2025
Powered by FUDForum. Page generated in 0.05628 seconds
