  Upgrade of Eclipse base of Eclipse RMF
By: Eclipse User on Thu, 30 May 2024
4 3755 Tue, 04 June 2024 16:54
  import csv with ProR
How to import CSV file withProR
By: Eclipse User on Tue, 12 May 2020
0 4629 Tue, 12 May 2020 14:50
  Import RMF in Eclipse Project
By: Eclipse User on Wed, 22 April 2020
0 5370 Wed, 22 April 2020 07:52
  Can I export Reqif files generated with ProR or Reqif Studio into XMI conforming to Reqif10.ecore?
By: Eclipse User on Mon, 13 April 2020
1 4625 Wed, 15 April 2020 03:17
  Was ECORE used in RMF?
By: Eclipse User on Mon, 24 February 2020
3 2347 Mon, 24 February 2020 14:08
  Generating Report ProR
Export to PDF or WORD or EXCEL
By: Eclipse User on Sun, 10 March 2019
1 9368 Thu, 06 February 2020 08:00
  automatic ID generation according to various patterns/criteria
how to generate different ID patterns?
0 9490 Sun, 10 March 2019 09:10
  Input Validation in ProR
0 8813 Sun, 10 March 2019 09:48
  Customizing the ID-Generator
How to customize parameters as n. of digits to display or other features
By: Eclipse User on Mon, 10 December 2018
1 2595 Fri, 14 December 2018 12:07
  How the ReqIF IDs are generated
By: Eclipse User on Fri, 19 October 2018
4 4390 Tue, 30 October 2018 21:52
  Help needed, plugin can not be installed: http://download.eclipse.org/rmf/updates/latest
By: Eclipse User on Sat, 29 September 2018
1 2532 Tue, 02 October 2018 10:00
icon13.gif Widget has the wrong parent
error opening specification
By: Eclipse User on Wed, 13 January 2016
3 4912 Tue, 03 April 2018 01:34
  XHTML rendering
How to render XHTML with ProR or ReqIF Studio
By: Eclipse User on Mon, 05 March 2018
3 4445 Tue, 06 March 2018 06:13
  Manage .reqif in git for multiple user input
how can multiple users have input into a single .reqif file using git
By: Eclipse User on Thu, 01 February 2018
1 2701 Mon, 05 February 2018 12:35
  ISpecificaiton error
By: Eclipse User on Mon, 29 February 2016
9 12707 Wed, 29 November 2017 16:48
  ReqIF and Gendoc
By: Eclipse User on Tue, 23 June 2015
4 6335 Wed, 21 June 2017 14:02
  API ti add content to Spec Object
By: Eclipse User on Mon, 14 November 2016
2 23859 Wed, 16 November 2016 04:28
icon5.gif How to open the SpecificationEditor programmatically
By: Eclipse User on Thu, 09 June 2016
4 6126 Tue, 21 June 2016 05:21
  Unified Column is not as per documentation
By: Eclipse User on Tue, 14 June 2016
4 5720 Thu, 16 June 2016 00:46
  Linking multiple headlines to a requirement
By: Eclipse User on Wed, 15 June 2016
1 3112 Wed, 15 June 2016 13:37
  Table object in Pro-R
By: Eclipse User on Tue, 07 June 2016
3 4580 Wed, 08 June 2016 08:18
  What version of eclipse?
By: Eclipse User on Tue, 19 April 2016
1 3701 Tue, 19 April 2016 13:05
  AttributeValueXHTML contains an object with illegal attributes
By: Eclipse User on Tue, 22 March 2016
2 5047 Wed, 23 March 2016 05:37
  Linking between specifications?
By: Eclipse User on Wed, 09 March 2016
0 5702 Wed, 09 March 2016 08:36
  How to set the remove git repository in tool?
By: Eclipse User on Fri, 26 February 2016
2 6744 Mon, 29 February 2016 06:03
icon3.gif Requirement-Diff
Diff-View between different versions of the same reqif-document
By: Eclipse User on Wed, 30 July 2014
13 11247 Wed, 24 February 2016 16:09
  Clear down presentation configuration errors
Don't want to have to revert to my earlier stored model...
By: Eclipse User on Wed, 17 February 2016
3 4378 Thu, 18 February 2016 05:58
  How can I set this to be green - Glossary
By: Eclipse User on Thu, 21 January 2016
3 3615 Fri, 22 January 2016 09:01
  JavaFX issues with the XHTML editor
2 3503 Thu, 21 January 2016 11:17
  Enumeration data type
3 4117 Wed, 20 January 2016 10:43
  Image support?
Can RMF/proR support embedding of images in a ReqIF requirement?
By: Eclipse User on Sat, 28 November 2015
1 3157 Sun, 29 November 2015 08:23
  Glossary desc/type reversed in tree
By: Eclipse User on Thu, 08 October 2015
2 3372 Thu, 08 October 2015 06:57
  What datatype required for Glossary?
By: Eclipse User on Tue, 29 September 2015
3 3777 Thu, 01 October 2015 10:50
  ID-Generator auto-numbering.
By: Eclipse User on Fri, 25 September 2015
6 7406 Tue, 29 September 2015 06:05
icon3.gif Creating SpecHierarchy Programmatically and Save to .reqif file
By: Eclipse User on Mon, 31 August 2015
1 9358 Thu, 03 September 2015 13:03
  CREATING REQIF SPECHIERARCHY AND SPECIFICATIONS PROGRAMMATICALLY
By: Eclipse User on Thu, 27 August 2015
4 4439 Fri, 28 August 2015 08:59
  Highlighting problems
By: Eclipse User on Wed, 12 August 2015
4 4205 Mon, 17 August 2015 16:50
  How to add an specHierarchy programmatically?
By: Eclipse User on Fri, 07 August 2015
1 2845 Fri, 07 August 2015 10:11
  Using Type attribute
By: Eclipse User on Thu, 23 July 2015
1 3992 Fri, 24 July 2015 14:41
  Comparing Specifications Error
By: Eclipse User on Mon, 13 July 2015
1 2667 Mon, 13 July 2015 14:16
  How can I import a CSV file?
By: Eclipse User on Wed, 07 January 2015
3 5889 Wed, 08 July 2015 20:31
  ReqIF <SPECIFICATIONS>
By: Eclipse User on Thu, 11 June 2015
3 3724 Fri, 19 June 2015 08:41
  Removing a link (specrelation)?
By: Eclipse User on Fri, 29 May 2015
6 5243 Fri, 05 June 2015 06:28
  ReqIF Purpose of SpecHierarchy.EditableAtts
By: Eclipse User on Thu, 28 May 2015
1 2995 Thu, 28 May 2015 12:32
  Renaming a headline
By: Eclipse User on Wed, 27 May 2015
1 2872 Wed, 27 May 2015 15:32
  Creating ReqIF model programmatically
By: Eclipse User on Sat, 23 May 2015
2 4449 Tue, 26 May 2015 02:13
  Serialization of EObject
By: Eclipse User on Tue, 14 April 2015
2 3240 Wed, 15 April 2015 07:46
  Processor XHTML elements
By: Eclipse User on Wed, 18 March 2015
1 4062 Fri, 20 March 2015 06:06
  Linking in between modules
Potential issues regarding collaborative working
By: Eclipse User on Wed, 11 March 2015
3 4065 Sat, 14 March 2015 16:25
  Xtext extension to ProR editor
By: Eclipse User on Fri, 06 June 2014
3 5274 Thu, 12 March 2015 06:15
  Setting Identifier of Elements
By: Eclipse User on Wed, 04 March 2015
3 3971 Thu, 05 March 2015 04:52
icon13.gif Changes to HTML Export
By: Eclipse User on Wed, 10 December 2014
3 3794 Sun, 14 December 2014 17:34
  Export in list-form possible?
By: Eclipse User on Mon, 15 September 2014
4 4613 Wed, 10 December 2014 11:18
  How to import RIF or export to RIF
By: Eclipse User on Mon, 28 April 2014
4 5642 Tue, 23 September 2014 09:39
  Delete a requirement?
By: Eclipse User on Thu, 18 September 2014
1 3718 Fri, 19 September 2014 03:08
  does it exist a complete chain for requirements managament, uml, development and tests
how maintain traceability among requirement management, uml, development and tests
By: Eclipse User on Wed, 17 September 2014
1 3405 Wed, 17 September 2014 10:28
  represent ProR SpecRelations with BIRT
By: Eclipse User on Wed, 03 September 2014
4 6021 Mon, 08 September 2014 02:40
  Glossary in ProR
By: Eclipse User on Thu, 07 August 2014
1 4377 Tue, 12 August 2014 16:35
  Linking and Tracing
By: Eclipse User on Thu, 10 July 2014
2 4477 Fri, 11 July 2014 02:53
  xhtml for RIF1.1
By: Eclipse User on Sun, 01 June 2014
3 4624 Tue, 10 June 2014 10:45
  How to collaborate with others using RMF?
By: Eclipse User on Wed, 28 May 2014
1 37737 Tue, 03 June 2014 15:44
icon5.gif Getting Started for non-experts
Templates and advice for those new to Requirements Management
By: Eclipse User on Thu, 08 May 2014
2 16246 Fri, 16 May 2014 06:29
  Why using new model instead of using the model generated by xsd file
By: Eclipse User on Wed, 07 May 2014
3 4807 Tue, 13 May 2014 07:07
  Using of GUI is really difficult
By: Eclipse User on Wed, 30 April 2014
1 6017 Wed, 30 April 2014 05:48
  RTF Presentation
How to specify
By: Eclipse User on Fri, 14 March 2014
3 4050 Thu, 17 April 2014 17:07
  Improving upon the id presentation
By: Eclipse User on Fri, 21 June 2013
25 18983 Thu, 10 April 2014 09:40
  Find/Filter/Sort requirements in a specification
By: Eclipse User on Mon, 07 April 2014
1 3544 Thu, 10 April 2014 09:38
  Linking between two reqif files
By: Eclipse User on Sun, 09 March 2014
2 4526 Fri, 14 March 2014 15:44
  XSLT for converting into LaTeX/PDF
By: Eclipse User on Sat, 08 March 2014
1 4097 Mon, 10 March 2014 05:39
  Color Requirements
By: Eclipse User on Thu, 29 August 2013
34 24788 Wed, 19 February 2014 14:06
  Presentation Question
By: Eclipse User on Sun, 29 December 2013
1 40286 Tue, 31 December 2013 12:49
  XML schema validation
By: Eclipse User on Wed, 18 December 2013
2 8254 Thu, 19 December 2013 05:28
  How to enter rich text
By: Eclipse User on Tue, 17 December 2013
4 7002 Wed, 18 December 2013 04:29
  Multiple presentation options per datatype?
2 7921 Wed, 18 December 2013 04:25
  Difference between nesting and Spec Hierarchy?
By: Eclipse User on Mon, 16 December 2013
2 12019 Wed, 18 December 2013 04:22
  Anti-aliasing in RTF presentation
2 6616 Wed, 18 December 2013 04:20
  Requirements with "no pure text" as Description
By: Eclipse User on Thu, 07 November 2013
1 4765 Fri, 08 November 2013 05:49
  Issues with linking
By: Eclipse User on Sun, 27 October 2013
4 4691 Mon, 28 October 2013 05:04
  Only string datatype available?
By: Eclipse User on Mon, 28 October 2013
1 3552 Mon, 28 October 2013 04:40
  How to copy a configuration from one ReqIf file no another
1 3768 Mon, 28 October 2013 04:37
  Any way to see relation type in table?
1 3971 Mon, 28 October 2013 04:35
  RMF/ProR 0.8.0 released
By: Eclipse User on Fri, 16 August 2013
0 3501 Fri, 16 August 2013 07:49
  Getting orphaned SpecObject back?
By: Eclipse User on Wed, 24 July 2013
1 3405 Wed, 24 July 2013 09:54
  Easier selection?
By: Eclipse User on Tue, 23 July 2013
1 3902 Wed, 24 July 2013 09:42
  Clarification on Spec hierachy
What kind of Spec Relation Type is(or is related to) a spec hierarchy
By: Eclipse User on Fri, 07 June 2013
3 10162 Tue, 11 June 2013 04:19
  Problems with unload Resources and reloading them and working with a new EditingDomain
By: Eclipse User on Thu, 23 May 2013
2 10543 Tue, 28 May 2013 04:18
  easy way to export / print reqs including link information
By: Eclipse User on Sat, 04 May 2013
6 8514 Tue, 21 May 2013 07:09
  Problems with tool-extentions
By: Eclipse User on Wed, 10 April 2013
8 13458 Thu, 02 May 2013 07:14
  0.5 -> 0.6 migration problem
I get only empty AttributeValueList
By: Eclipse User on Fri, 22 March 2013
1 4895 Mon, 25 March 2013 06:22
  Latest Version of Agile Grid
By: Eclipse User on Sat, 22 December 2012
2 6597 Thu, 21 March 2013 08:39
  Can't get standalone ProR to work
By: Eclipse User on Thu, 28 February 2013
5 7361 Fri, 01 March 2013 02:45
  RIF <-> ReqIF
Are there any plans to provided converters between RIF and ReqIF formats?
By: Eclipse User on Fri, 22 February 2013
1 4574 Mon, 25 February 2013 09:19
  RMF Standalone
By: Eclipse User on Fri, 04 January 2013
3 7586 Mon, 07 January 2013 09:51
  xmi serialization of reqif model
By: Eclipse User on Wed, 14 November 2012
1 4914 Thu, 15 November 2012 09:56
  Links to other documents
Tables, UML drawings etc.
By: Eclipse User on Mon, 15 October 2012
2 5952 Tue, 16 October 2012 08:55
  How to Get Started
Is there a step by step guide?
By: Eclipse User on Fri, 05 October 2012
5 6768 Mon, 08 October 2012 03:15
  how to use use RMF core to generate ReqIF
using RMF core to generate ReqIF
By: Eclipse User on Mon, 24 September 2012
5 10090 Sun, 07 October 2012 15:16
  Internationalizing ProR
0 5424 Fri, 05 October 2012 04:52
  Mylyn Connector for ReqIF
By: Eclipse User on Thu, 08 December 2011
7 10792 Fri, 31 August 2012 10:41
  Need Suggestions For a Good Formal Requirements Tool
By: Eclipse User on Fri, 24 August 2012
1 4205 Fri, 24 August 2012 09:40
  Wrong Post Deleted By Owner
1 4061 Fri, 24 August 2012 09:32
  ProR support for Specifications Relation Groups
By: Eclipse User on Wed, 15 August 2012
4 7891 Fri, 17 August 2012 11:04
  Why is Formal Requirements Tool is Needed?
By: Eclipse User on Thu, 09 August 2012
1 5615 Tue, 14 August 2012 03:56
  Defining an enumerations values?
How do you define the values in an Enumeration Datatype?
By: Eclipse User on Fri, 03 August 2012
1 5038 Mon, 06 August 2012 03:58
  More detail please
By: Eclipse User on Wed, 01 August 2012
2 5460 Thu, 02 August 2012 03:07
  More detail please
Could we have more details about ProR usage
0 4664 Wed, 01 August 2012 13:03
  Can I have some dog food please?
Eclipse project of the requirements for ProR itself?
By: Eclipse User on Thu, 26 July 2012
3 5437 Fri, 27 July 2012 09:06
  Importing ReqIf file into ProR
By: Eclipse User on Fri, 20 July 2012
9 11771 Sun, 22 July 2012 10:52
  Custom Properties Tab for a specific Attribute Definition
By: Eclipse User on Tue, 26 June 2012
8 8531 Thu, 28 June 2012 08:00
  org.agilemore.agilegrid 1.2.3 can not be resolved
By: Eclipse User on Thu, 21 June 2012
3 6543 Mon, 25 June 2012 06:55
  Display "Spec-Hierarchy"'s long-name attribute in ProR's Specification Editor
By: Eclipse User on Tue, 12 June 2012
3 5656 Tue, 12 June 2012 14:43
  Proposal for importing requirements from Excel
By: Eclipse User on Sun, 18 March 2012
3 10022 Tue, 12 June 2012 09:49
  New ProR Integration Release Available (0.2.0)
By: Eclipse User on Fri, 20 April 2012
0 8068 Fri, 20 April 2012 04:20
  The import org.eclipse.rmf.reqif10 cannot be resolved
By: Eclipse User on Mon, 09 April 2012
20 18850 Thu, 12 April 2012 14:28
  target and product in releng-projects
By: Eclipse User on Fri, 16 March 2012
2 4867 Fri, 16 March 2012 15:19
  ReqIF 1.0.1 already supported?
By: Eclipse User on Mon, 13 February 2012
2 6056 Tue, 06 March 2012 05:00
  XhtmlContent
By: Eclipse User on Fri, 17 February 2012
1 4909 Fri, 17 February 2012 07:00
  ProR Presentation-Tutorial
By: Eclipse User on Sun, 05 February 2012
1 4818 Sun, 05 February 2012 11:15
  EMF book
1 4586 Sun, 05 February 2012 11:10
  Reporting bug(s) in ProR
By: Eclipse User on Mon, 23 January 2012
2 4858 Tue, 24 January 2012 15:45
  Status
By: Eclipse User on Thu, 29 December 2011
1 4741 Thu, 29 December 2011 15:20
  Where can I get the Source?
By: Eclipse User on Thu, 03 November 2011
1 5174 Fri, 04 November 2011 12:40
  Welcome to eclipse.rmf
By: Eclipse Webmaster on Mon, 29 August 2011
0 5576 Mon, 29 August 2011 11:55
Current Time: Sat Nov 01 13:02:15 EDT 2025
Powered by FUDForum. Page generated in 0.03416 seconds
