Accessing value of inherited tags By: Eclipse User on Thu, 26 September 2024 |
5786 |
Fri, 27 September 2024 15:21 By: Eclipse User  |
Reading SysML model from XMI I would like to read a SysML file exported to XMI By: Eclipse User on Thu, 27 June 2024 |
2765 |
Mon, 15 July 2024 07:30 By: Eclipse User  |
How to get stereotypes after loading XMI resource By: Eclipse User on Thu, 07 March 2024 |
2772 |
Fri, 15 March 2024 05:40 By: Eclipse User  |
How to set multiple values for a property of a stereotype? By: Eclipse User on Fri, 26 January 2024 |
1628 |
Mon, 05 February 2024 10:02 By: Eclipse User  |
How to generate UMLPackage object from .uml file? org.eclipse.uml2.uml api By: Eclipse User on Tue, 22 March 2022 |
4947 |
Sat, 02 September 2023 04:19 By: Eclipse User  |
Programatically load and save sequence diagram By: Eclipse User on Thu, 26 November 2020 |
3417 |
Sat, 02 September 2023 03:00 By: Eclipse User  |
Feature 'eAnnotations' not found. By: Eclipse User on Tue, 28 March 2023 |
1971 |
Wed, 29 March 2023 14:11 By: Eclipse User  |
Associations to EReferences in UML2 profile to .ecore/.genmodel By: Eclipse User on Tue, 21 February 2023 |
2108 |
Wed, 22 February 2023 10:57 By: Eclipse User  |
emx file conforming both to UML profile and UML metamodel By: Eclipse User on Thu, 22 December 2022 |
1747 |
Thu, 22 December 2022 17:40 By: Eclipse User  |
EPX file to Ecore file By: Eclipse User on Wed, 21 December 2022 |
1538 |
Thu, 22 December 2022 15:05 By: Eclipse User  |
Problems with generation of model instance Create model instance from .ecore file generated starting from UMLs By: Eclipse User on Wed, 27 July 2022 |
1996 |
Wed, 27 July 2022 15:50 By: Eclipse User  |
What is the best way to publish UML models and profiles for reuse? Can we setup a development and production environment? By: Eclipse User on Thu, 23 June 2022 |
2617 |
Thu, 23 June 2022 11:27 By: Eclipse User  |
Exception raised when applying stereotype By: Eclipse User on Wed, 05 February 2020 |
3593 |
Fri, 10 June 2022 14:13 By: Eclipse User  |
RE: steretype on multiple different attributes By: Eclipse User on Mon, 23 May 2022 |
8062 |
Tue, 31 May 2022 14:21 By: Eclipse User  |
[SOLVED] Why a stereotype application breaks when the same profile is re-applied? One has to provide a profile URI to be able to re-apply it onto a model without losing changes. By: Eclipse User on Tue, 24 May 2022 |
2737 |
Tue, 24 May 2022 13:26 By: Eclipse User  |
[SOLVED] Profile and stereotypes are not applied in the "Intro to Profile" example By: Eclipse User on Thu, 07 April 2022 |
2949 |
Fri, 08 April 2022 09:28 By: Eclipse User  |
UML 2.5.1 By: Eclipse User on Thu, 17 March 2022 |
2662 |
Thu, 17 March 2022 05:28 By: Eclipse User  |
Stereotype.getAllExtendedMetaclasses() does not respect propety visibility By: Eclipse User on Mon, 01 November 2021 |
4939 |
Thu, 04 November 2021 07:05 By: Eclipse User  |
How to get applied stereotypes of stereotypes How to get applied stereotypes of stereotypes for controlling m2t generation By: Eclipse User on Tue, 14 September 2021 |
2509 |
Thu, 16 September 2021 14:40 By: Eclipse User  |
Textual syntax for UML state machines By: Eclipse User on Mon, 19 April 2021 |
1847 |
Mon, 19 April 2021 07:35 By: Eclipse User  |
UML RT metamodel By: Eclipse User on Mon, 01 March 2021 |
2743 |
Mon, 01 March 2021 09:50 By: Eclipse User  |
Instance in class diagram Why are we unable to add instance and class within same class diagram? By: Eclipse User on Mon, 08 February 2021 |
1681 |
Mon, 08 February 2021 09:29 By: Eclipse User  |
JUnit Test UML Model setValue IllegalArgumentException By: Eclipse User on Mon, 30 November 2020 |
336895 |
Fri, 18 December 2020 04:30 By: Eclipse User  |
problems saving stereotypes By: Eclipse User on Fri, 04 January 2019 |
6690 |
Sat, 05 December 2020 06:59 By: Eclipse User  |
Profile definition results in dangling references when using a model library By: Eclipse User on Fri, 06 November 2020 |
2047 |
Fri, 06 November 2020 07:49 By: Eclipse User  |
Change parent/owner By: Eclipse User on Wed, 30 September 2020 |
2669 |
Thu, 01 October 2020 08:11 By: Eclipse User  |
Reading and applying profile geneated through MagicDraw I cannot apply a stereotype to a UML element By: Eclipse User on Fri, 18 September 2020 |
2576 |
Fri, 18 September 2020 14:05 By: Eclipse User  |
View UML Abstract Metamodel XMI file in Eclipse Use Eclipse modeling tools to view/browse UML Abstract Syntax Metamodel By: Eclipse User on Sun, 03 May 2020 |
8769 |
Fri, 08 May 2020 00:59 By: Eclipse User  |
XMI File generated from Erwin as UML Export - How to read? Import erwin exported file By: Eclipse User on Tue, 07 April 2020 |
2458 |
Wed, 08 April 2020 16:02 By: Eclipse User  |
Forum on Privacy and Data Protection Challenges in System Development By: Eclipse User on Thu, 27 February 2020 |
3809 |
Thu, 27 February 2020 17:54 By: Eclipse User  |
Business Key By: Eclipse User on Fri, 25 October 2019 |
2735 |
Fri, 25 October 2019 16:46 By: Eclipse User  |
Difference uml2 vs emf uml2 vs emf By: Eclipse User on Thu, 26 September 2019 |
3026 |
Wed, 02 October 2019 13:34 By: Eclipse User  |
What Industry Wants from Academia in Software Modeling By: Eclipse User on Wed, 01 May 2019 |
30057 |
Wed, 01 May 2019 11:26 By: Eclipse User  |
Profiles doesn't work correctly in XMI-serialized UML By: Eclipse User on Tue, 23 June 2015 |
7615 |
Tue, 30 April 2019 04:15 By: Eclipse User  |
How to load and use MARTE profile Use MARTE stereotypes in a standalone Java application By: Eclipse User on Fri, 19 April 2019 |
41562 |
Fri, 19 April 2019 12:57 By: Eclipse User  |
Tag elements of a sequence diagram in an emx file (UML2) By: Eclipse User on Tue, 09 April 2019 |
6133 |
Sat, 13 April 2019 15:53 By: Eclipse User  |
Get all class attributes, including those from association ends By: Eclipse User on Sun, 03 March 2019 |
18599 |
Fri, 08 March 2019 08:20 By: Eclipse User  |
Ecore to UML By: Eclipse User on Thu, 28 February 2019 |
2802 |
Thu, 28 February 2019 11:05 By: Eclipse User  |
problem with IntroductionToUML2Profiles By: Eclipse User on Sun, 17 June 2018 |
6926 |
Fri, 04 January 2019 08:26 By: Eclipse User  |
[solved] getApplicableStereotypes() is empty Unable to get the applicable stereotypes of an applie profile By: Eclipse User on Mon, 19 November 2018 |
3847 |
Thu, 22 November 2018 02:56 By: Eclipse User  |
XMI model versions By: Eclipse User on Mon, 15 October 2018 |
3476 |
Wed, 17 October 2018 14:04 By: Eclipse User  |
reference to attribute in tagged value reference to attribute in tagged value By: Eclipse User on Mon, 01 October 2018 |
5429 |
Wed, 03 October 2018 04:38 By: Eclipse User  |
How to get instance of stereotype as generated ecore class instance By: Eclipse User on Tue, 12 June 2018 |
4878 |
Wed, 15 August 2018 22:02 By: Eclipse User  |
XML/XMI import/export issues? By: Eclipse User on Wed, 11 June 2008 |
32 |
25957 |
Mon, 23 July 2018 12:12 By: Eclipse User  |
OMG XMI to Eclipse UML or to Ecore - best option? OMG XMI to Eclipse UML or to Ecore - best option? By: Eclipse User on Tue, 17 April 2018 |
11419 |
Fri, 20 April 2018 03:17 By: Eclipse User  |
Custom field on Property object in metamodel How to create a custom field (free text as string type) associated with evry Property in the IBM RSA Model By: Eclipse User on Wed, 18 April 2018 |
5777 |
Thu, 19 April 2018 04:25 By: Eclipse User  |
Convert .uml to .ecore in Oxygen Convert .uml to .ecore in Oxygen By: Eclipse User on Tue, 17 April 2018 |
3341 |
Tue, 17 April 2018 05:52 By: Eclipse User  |
Connect StateInvariant to a State By: Eclipse User on Tue, 06 February 2018 |
4048 |
Tue, 06 February 2018 09:40 By: Eclipse User  |
Standalone: load profile from Papyrus models By: Eclipse User on Tue, 28 November 2017 |
8989 |
Thu, 30 November 2017 11:15 By: Eclipse User  |
Standalone program : error loading old model (ns=http://www.eclipse.org/uml2/2.1.0/UML) By: Eclipse User on Wed, 18 October 2017 |
6221 |
Thu, 19 October 2017 06:25 By: Eclipse User  |
Writing XML file from UML Model misses some data Provided Interfaces of UML Port Element are not written to XML file By: Eclipse User on Thu, 28 March 2013 |
9356 |
Tue, 26 September 2017 09:48 By: Eclipse User  |
Reusing OMG Profiles created with Magic Draw I want to reuse an OMG Profile for the ODM 1.1 (created with Magic Draw) By: Eclipse User on Wed, 07 June 2017 |
19858 |
Wed, 21 June 2017 10:06 By: Eclipse User  |
There may not be two classifiers named 'CatchClause_CatchClause' By: Eclipse User on Wed, 14 June 2017 |
2835 |
Wed, 14 June 2017 16:40 By: Eclipse User  |
UML to Ecore, where are the TemplateBindings ? By: Eclipse User on Fri, 31 March 2017 |
11076 |
Fri, 31 March 2017 08:34 By: Eclipse User  |
[CDO/UML2/MARTE] Marte profile issue By: Eclipse User on Tue, 07 March 2017 |
13654 |
Tue, 07 March 2017 03:24 By: Eclipse User  |
Get classes from a model with the API By: Eclipse User on Mon, 20 February 2017 |
5380 |
Wed, 22 February 2017 05:30 By: Eclipse User  |
Get and create SysML subprofiles (SysML 1.4 Memtamodel) By: Eclipse User on Thu, 02 February 2017 |
6238 |
Mon, 06 February 2017 11:21 By: Eclipse User  |
Cannot get Instances of Applied Stereotypes Element.getStereotypeApplications() returns only DynamicEObjectImpl Instances By: Eclipse User on Thu, 02 February 2017 |
4959 |
Fri, 03 February 2017 04:38 By: Eclipse User  |
getAppliedStereotypes is empty but the stereotype has been applied By: Eclipse User on Mon, 26 January 2015 |
9882 |
Thu, 02 February 2017 15:51 By: Eclipse User  |
XPath query for list of UML class attributes that are not associations By: Eclipse User on Fri, 27 January 2017 |
4794 |
Mon, 30 January 2017 17:53 By: Eclipse User  |
UML/OCL metamodel documentation By: Eclipse User on Mon, 23 January 2017 |
13310 |
Tue, 24 January 2017 02:11 By: Eclipse User  |
How to access Message arguments sent with a signal triggering a transition Using EMF in Java code By: Eclipse User on Mon, 19 December 2016 |
16760 |
Sat, 07 January 2017 15:11 By: Eclipse User  |
Enumeration.createOwnedLiteral does not validate By: Eclipse User on Thu, 15 December 2016 |
4779 |
Fri, 23 December 2016 16:24 By: Eclipse User  |
SySML in Java SYSml By: Eclipse User on Tue, 06 December 2016 |
7410 |
Tue, 20 December 2016 09:58 By: Eclipse User  |
Preferences for validation in UML2 By: Eclipse User on Thu, 08 December 2016 |
10637 |
Sun, 18 December 2016 10:28 By: Eclipse User  |
order of the ends of a binary association How Papyrus UML supports order of the ends of an association By: Eclipse User on Tue, 22 November 2016 |
14191 |
Thu, 24 November 2016 20:39 By: Eclipse User  |
Read sequence diagram by its Xmi By: Eclipse User on Tue, 01 November 2016 |
4564 |
Tue, 01 November 2016 16:01 By: Eclipse User  |
read uml model program By: Eclipse User on Thu, 29 September 2016 |
5996 |
Mon, 03 October 2016 10:28 By: Eclipse User  |
Dangling references when creating profile By: Eclipse User on Wed, 10 July 2013 |
9026 |
Thu, 29 September 2016 10:24 By: Eclipse User  |
Problem in ElementOperations.getRelationships() By: Eclipse User on Thu, 28 April 2016 |
4256 |
Thu, 22 September 2016 06:14 By: Eclipse User  |
31954 |
Wed, 31 August 2016 14:44 By: Eclipse Webmaster  |
31768 |
31661 |
31779 |
Regenerating an existing Static Profile from cli/CI? By: Eclipse User on Mon, 15 August 2016 |
7416 |
Mon, 15 August 2016 08:49 By: Eclipse User  |
Question about stereotype Instance By: Eclipse User on Sat, 16 July 2016 |
6054 |
Wed, 20 July 2016 19:02 By: Eclipse User  |
Dependency hell with org.eclipse.uml2.types and Maven org.eclipse.uml2.types dependency in Maven Central is out-of-date By: Eclipse User on Thu, 14 July 2016 |
7851 |
Fri, 15 July 2016 10:56 By: Eclipse User  |
Missing SendOperationEvent, ReceiveOperationEvent in recent versions of UML2 By: Eclipse User on Tue, 12 July 2016 |
3096 |
Tue, 12 July 2016 08:49 By: Eclipse User  |
Resolve proxy containing qualifiedName How to manage simple reference of UML elements by its qualifiedName in eProxy By: Eclipse User on Mon, 04 July 2016 |
3542 |
Tue, 05 July 2016 11:51 By: Eclipse User  |
How to add time related information in state machine? By: Eclipse User on Mon, 04 July 2016 |
4506 |
Mon, 04 July 2016 01:54 By: Eclipse User  |
XMI idref reading error By: Eclipse User on Fri, 03 June 2016 |
6544 |
Fri, 03 June 2016 13:10 By: Eclipse User  |
How to use UML2 with Maven By: Eclipse User on Thu, 26 May 2016 |
5621 |
Fri, 27 May 2016 13:01 By: Eclipse User  |
How to manipulate UML Class Diagram Elements By: Eclipse User on Mon, 23 May 2016 |
5252 |
Wed, 25 May 2016 11:55 By: Eclipse User  |
Get the file (.uml) generated using a code to access the content of the uml file By: Eclipse User on Mon, 02 May 2016 |
5782 |
Wed, 04 May 2016 08:41 By: Eclipse User  |
PluginUML2: Validating a uml diagram which class implements the validation of an UML diagram By: Eclipse User on Wed, 30 March 2016 |
8884 |
Fri, 08 April 2016 08:44 By: Eclipse User  |
saving a model content into a string By: Eclipse User on Wed, 30 March 2016 |
3521 |
Wed, 30 March 2016 14:16 By: Eclipse User  |
UML M2M Epsilon Java2UML transformation ParameterDirectionKind By: Eclipse User on Wed, 16 March 2016 |
3725 |
Wed, 16 March 2016 15:23 By: Eclipse User  |
Problem loading UML in stand alone application Problem to load an UML model in a stand alone application By: Eclipse User on Mon, 16 April 2012 |
12792 |
Tue, 08 March 2016 07:51 By: Eclipse User  |
UML diagram for model AND metamodel in MDA? By: Eclipse User on Tue, 23 February 2016 |
7301 |
Tue, 01 March 2016 13:55 By: Eclipse User  |
Stereotype definitions and applications in the same file By: Eclipse User on Wed, 17 February 2016 |
8205 |
Wed, 17 February 2016 14:50 By: Eclipse User  |
how to setValue() of a stereotype property that refers to another stereotype By: Eclipse User on Wed, 10 February 2016 |
5267 |
Wed, 10 February 2016 14:34 By: Eclipse User  |
How to convert the .uml generated from Magic draw to .ecore using UML2EcoreConverter By: Eclipse User on Wed, 10 February 2016 |
6535 |
Wed, 10 February 2016 08:07 By: Eclipse User  |
Re: [EMF] Loading UML Magicdraw models By: Eclipse User on Tue, 07 October 2008 |
7192 |
Mon, 08 February 2016 09:30 By: Eclipse User  |
How to reference UML elements from Ecore models? By: Eclipse User on Fri, 05 February 2016 |
4181 |
Fri, 05 February 2016 07:41 By: Eclipse User  |
contains an unresolved proxy '<null-named-ProfileImpl> When i try to generate artifact for my model i get this error stating "Error The feature 'uml::Relationship::relatedElement' of 'TestModel::ProfileApplication' contains an unresolved proxy '<n By: Eclipse User on Tue, 02 February 2016 |
7815 |
Tue, 02 February 2016 01:50 By: Eclipse User  |
How to load Applied Stereotypes By: Eclipse User on Mon, 18 January 2016 |
5203 |
Mon, 25 January 2016 08:43 By: Eclipse User  |
Generate big UML state charts ? By: Eclipse User on Wed, 20 January 2016 |
7582 |
Wed, 20 January 2016 01:43 By: Eclipse User  |
UML: How to load an existing UML profile By: Eclipse User on Sun, 20 December 2015 |
8306 |
Fri, 08 January 2016 14:47 By: Eclipse User  |
Copying a UML2 model including a deep copy of PackageImports By: Eclipse User on Mon, 14 December 2015 |
6341 |
Fri, 08 January 2016 09:36 By: Eclipse User  |
load uml model for java By: Eclipse User on Wed, 02 December 2015 |
7640 |
Wed, 02 December 2015 18:00 By: Eclipse User  |
Performance with Stereotypes (UMLUtil.getNamedElement()) By: Eclipse User on Thu, 26 November 2015 |
3380 |
Thu, 26 November 2015 11:40 By: Eclipse User  |
Inconsistent genmodel behavior By: Eclipse User on Thu, 05 November 2015 |
6410 |
Sat, 14 November 2015 17:04 By: Eclipse User  |
View UML diagram on Eclipse By: Eclipse User on Tue, 06 October 2015 |
5381 |
Sat, 10 October 2015 04:30 By: Eclipse User  |
Stereotype attribute using ATL Picking (deriving) Stereotype attribute using ATL in Eclipse Luna By: Eclipse User on Wed, 02 September 2015 |
5752 |
Wed, 02 September 2015 17:03 By: Eclipse User  |
profile uml By: Eclipse User on Thu, 20 August 2015 |
3992 |
Thu, 20 August 2015 12:22 By: Eclipse User  |
Resolving relative URI's in references UML2 model load with relative element references between model fragments By: Eclipse User on Wed, 08 July 2015 |
9570 |
Tue, 28 July 2015 08:14 By: Eclipse User  |
memberEnds not correctly ordered? By: Eclipse User on Wed, 08 July 2015 |
4611 |
Thu, 09 July 2015 09:49 By: Eclipse User  |
[Searching] for UML-Lib to draw an Component diagram By: Eclipse User on Tue, 07 July 2015 |
3505 |
Tue, 07 July 2015 08:51 By: Eclipse User  |
UML 2.5 DI support By: Eclipse User on Mon, 06 July 2015 |
4472 |
Mon, 06 July 2015 10:31 By: Eclipse User  |
Importing IFML metamodel and profile By: Eclipse User on Thu, 19 February 2015 |
5651 |
Sat, 20 June 2015 08:44 By: Eclipse User  |
Question about the EMF implementation of the UML metamodel Regarding the containments associations By: Eclipse User on Wed, 17 June 2015 |
4025 |
Fri, 19 June 2015 08:42 By: Eclipse User  |
XMI serialization By: Eclipse User on Sun, 07 June 2015 |
3142 |
Mon, 08 June 2015 10:36 By: Eclipse User  |
Listen for (re)application of a profile By: Eclipse User on Mon, 25 May 2015 |
4883 |
Tue, 02 June 2015 03:48 By: Eclipse User  |
Cannot apply SysML stereotype By: Eclipse User on Thu, 28 May 2015 |
3667 |
Fri, 29 May 2015 12:12 By: Eclipse User  |
UML2 jars in maven repositories By: Eclipse User on Mon, 04 May 2015 |
3880 |
Mon, 04 May 2015 06:39 By: Eclipse User  |
Sequence Diagrams Repository By: Eclipse User on Sat, 11 April 2015 |
5116 |
Sat, 11 April 2015 15:08 By: Eclipse User  |
Popup menu enabling for a specific named UML package? By: Eclipse User on Thu, 09 April 2015 |
3652 |
Thu, 09 April 2015 15:04 By: Eclipse User  |
Empty comments in imported XMI-based UML By: Eclipse User on Mon, 30 March 2015 |
7798 |
Wed, 01 April 2015 10:49 By: Eclipse User  |
how to create a UML2 V2.1 model By: Eclipse User on Fri, 27 March 2015 |
4162 |
Fri, 27 March 2015 08:37 By: Eclipse User  |
Problem to load Rose model By: Eclipse User on Mon, 23 March 2015 |
6111 |
Wed, 25 March 2015 05:08 By: Eclipse User  |
find elements by type and by name By: Eclipse User on Fri, 06 February 2015 |
3351 |
Fri, 06 February 2015 09:14 By: Eclipse User  |
Classifier.getInheritedMembers() method vs UML inheritance semantics By: Eclipse User on Fri, 06 February 2015 |
3432 |
Fri, 06 February 2015 07:40 By: Eclipse User  |
getAppliedStereotypes() does not work when model and profile are in the same file ? By: Eclipse User on Fri, 30 January 2015 |
5834 |
Tue, 03 February 2015 04:06 By: Eclipse User  |
Registering and loading a profile programatically (standalone) By: Eclipse User on Mon, 19 January 2015 |
5366 |
Tue, 20 January 2015 16:36 By: Eclipse User  |
4497 |
Mon, 19 January 2015 17:47 By: Eclipse User  |
Stereotype owning two specialization By: Eclipse User on Thu, 15 January 2015 |
3710 |
Thu, 15 January 2015 16:04 By: Eclipse User  |
Property#setDefaultValue of EnumerationLiteral By: Eclipse User on Wed, 14 January 2015 |
3756 |
Wed, 14 January 2015 11:17 By: Eclipse User  |
Rich Text Editor for SysML Comments usage of RTF in Papyrus By: Eclipse User on Sun, 04 January 2015 |
3496 |
Mon, 05 January 2015 10:02 By: Eclipse User  |
Inconsistent end-of-line with UML model editor on windows xp/windows 7 UNIX/Windows EOL wars still ask for tribute By: Eclipse User on Tue, 09 December 2014 |
4730 |
Thu, 11 December 2014 15:46 By: Eclipse User  |
Auto imports org.eclipse.uml2.uml By: Eclipse User on Wed, 03 December 2014 |
5133 |
Wed, 03 December 2014 09:21 By: Eclipse User  |
How to specify unspecified navigability? By: Eclipse User on Mon, 24 November 2014 |
7266 |
Wed, 03 December 2014 04:27 By: Eclipse User  |
Help applying RDF/ODM profile By: Eclipse User on Fri, 18 November 2011 |
17817 |
Wed, 26 November 2014 03:27 By: Eclipse User  |
Allocation relationship Where is the allocation relationship ? By: Eclipse User on Fri, 14 November 2014 |
3655 |
Fri, 14 November 2014 09:18 By: Eclipse User  |
How to apply a profile to an Activity Diagram I'd like to know how I can apply an UML profile to an Activity Diagram By: Eclipse User on Thu, 30 October 2014 |
4190 |
Thu, 30 October 2014 17:37 By: Eclipse User  |
Retrieving only the "most specific" relationships of a Class By: Eclipse User on Wed, 22 October 2014 |
3571 |
Wed, 22 October 2014 12:56 By: Eclipse User  |
Anyone developing Professional Software using UML diagrams and Eclipse? By: Eclipse User on Tue, 12 March 2013 |
13751 |
Mon, 06 October 2014 05:58 By: Eclipse User  |
defining a new data type By: Eclipse User on Fri, 30 May 2014 |
9064 |
Mon, 06 October 2014 05:45 By: Eclipse User  |
exception when creating genmodel (Juno) By: Eclipse User on Sun, 15 July 2012 |
8110 |
Mon, 25 August 2014 11:54 By: Eclipse User  |
ExportAllDiagrams/Model Validation very slow on Luna By: Eclipse User on Wed, 30 July 2014 |
6993 |
Tue, 19 August 2014 06:31 By: Eclipse User  |
Problems with profile "file:" URI in UML Model Editor By: Eclipse User on Tue, 11 March 2008 |
12035 |
Sun, 17 August 2014 18:37 By: Eclipse User  |
Java code on how to copy UML package to another UML Package EMF By: Eclipse User on Thu, 14 August 2014 |
4640 |
Fri, 15 August 2014 04:21 By: Eclipse User  |
UML 2.4 schema By: Eclipse User on Fri, 08 February 2013 |
27 |
25535 |
Mon, 11 August 2014 21:47 By: Eclipse User  |
Cannot Apply SysML Stereotypes Unable to apply stereotypes from SysML profiles but applying stereotypes from custom profile works well By: Eclipse User on Wed, 23 July 2014 |
5548 |
Fri, 25 July 2014 10:39 By: Eclipse User  |
Documentation of the UML2/EMF codegen Urgent need for more information about the design of the codegen for subsetting and redefinition By: Eclipse User on Wed, 16 July 2014 |
4965 |
Wed, 16 July 2014 04:45 By: Eclipse User  |
Notification problem with class package Notification problem when the package of a class changed By: Eclipse User on Fri, 04 July 2014 |
4025 |
Thu, 10 July 2014 08:57 By: Eclipse User  |
IntroductionToUMLProfiles Question By: Eclipse User on Thu, 29 May 2014 |
10625 |
Tue, 03 June 2014 09:48 By: Eclipse User  |
EMF - not possible to create a profile model By: Eclipse User on Mon, 05 May 2014 |
7247 |
Wed, 21 May 2014 16:31 By: Eclipse User  |
UML-specific Diagnostician? By: Eclipse User on Mon, 19 May 2014 |
4076 |
Mon, 19 May 2014 09:08 By: Eclipse User  |
LiteralUnlimitedNatural why int why is LiteralUnlimitedNatural a int and not a long By: Eclipse User on Tue, 29 April 2014 |
6986 |
Wed, 30 April 2014 11:38 By: Eclipse User  |
Check if given Stereotype can be applied By: Eclipse User on Thu, 24 April 2014 |
6448 |
Thu, 24 April 2014 20:02 By: Eclipse User  |
load Standard L2 Profile programmatically By: Eclipse User on Thu, 24 April 2014 |
3429 |
Thu, 24 April 2014 10:27 By: Eclipse User  |
fUML- and ALF-Metamodels By: Eclipse User on Tue, 15 April 2014 |
5432 |
Wed, 16 April 2014 04:29 By: Eclipse User  |
How design diagrams in Eclipse Classic requirements for design By: Eclipse User on Fri, 11 April 2014 |
3504 |
Sat, 12 April 2014 12:47 By: Eclipse User  |
how to make instance model from ecore file By: Eclipse User on Sun, 23 May 2010 |
8294 |
Thu, 10 April 2014 02:44 By: Eclipse User  |
Retrieving applied stereotypes By: Eclipse User on Wed, 18 August 2010 |
10715 |
Mon, 31 March 2014 05:57 By: Eclipse User  |
stereotypes not found on model reload UML MARTE stereotypes not found when the same model is deserialized a second time By: Eclipse User on Wed, 19 March 2014 |
5240 |
Tue, 25 March 2014 07:55 By: Eclipse User  |
How to get diagram information from XMI2.1 file exported by Enterprise Architect By: Eclipse User on Sun, 13 May 2012 |
10838 |
Sat, 15 March 2014 08:14 By: Eclipse User  |
Diagramming options By: Eclipse User on Wed, 05 March 2014 |
3466 |
Wed, 05 March 2014 08:18 By: Eclipse User  |
Re: PackageNotFoundException: Package with uri 'http://schema.omg.org/spec/XMI/2.1' not found By: Eclipse User on Mon, 02 February 2009 |
17041 |
Tue, 18 February 2014 10:38 By: Eclipse User  |
Eclipse UML Profiles Repository now available! By: Eclipse User on Thu, 13 February 2014 |
7854 |
Fri, 14 February 2014 05:56 By: Eclipse User  |
No outline view in default UML editor? By: Eclipse User on Wed, 05 February 2014 |
5078 |
Wed, 05 February 2014 11:07 By: Eclipse User  |
Problem reading model with SysML 1.3 stereotypes applied By: Eclipse User on Mon, 23 December 2013 |
8399 |
Mon, 06 January 2014 14:40 By: Eclipse User  |
Problems in RedefinableTemplateSignature NullPointerException handling associations of RedefinableTemplateSignature By: Eclipse User on Tue, 07 August 2012 |
9373 |
Mon, 06 January 2014 01:17 By: Eclipse User  |
UML help By: Eclipse User on Wed, 11 December 2013 |
7778 |
Thu, 12 December 2013 10:58 By: Eclipse User  |
Error when with classifier reference in EnumerationLiterals By: Eclipse User on Mon, 09 September 2013 |
6056 |
Fri, 29 November 2013 06:42 By: Eclipse User  |
update attributes of class programmatically By: Eclipse User on Wed, 20 November 2013 |
5112 |
Wed, 20 November 2013 05:25 By: Eclipse User  |
OCL expression attributes of different should not have the same name By: Eclipse User on Tue, 19 November 2013 |
5604 |
Wed, 20 November 2013 02:07 By: Eclipse User  |
Binary serialization broken with UML2 Kepler ? By: Eclipse User on Fri, 01 November 2013 |
11102 |
Fri, 15 November 2013 09:30 By: Eclipse User  |
inheritance of stereotypes in subclasses By: Eclipse User on Tue, 12 November 2013 |
18075 |
Fri, 15 November 2013 08:18 By: Eclipse User  |
Register a Profile programmatically By: Eclipse User on Sun, 03 November 2013 |
9706 |
Fri, 08 November 2013 05:57 By: Eclipse User  |
Class and Package diagrams for eclipse api online or offine class and package diagrams for eclipse api By: Eclipse User on Thu, 07 November 2013 |
4462 |
Thu, 07 November 2013 04:25 By: Eclipse User  |
UMLPackage.eINSTANCE.eClass() is ecore.EPackage? By: Eclipse User on Tue, 05 November 2013 |
8594 |
Wed, 06 November 2013 11:26 By: Eclipse User  |
connectors By: Eclipse User on Wed, 23 October 2013 |
4857 |
Wed, 23 October 2013 16:41 By: Eclipse User  |
Applying stereotype to property as association end throws IllegalArgumentException By: Eclipse User on Tue, 17 July 2012 |
18 |
29920 |
Wed, 23 October 2013 16:08 By: Eclipse User  |
Re: Multiple Inheritance By: Eclipse User on Mon, 21 October 2013 |
5271 |
Tue, 22 October 2013 09:58 By: Eclipse User  |
Sequence diagram: two messages with executed at the same time By: Eclipse User on Wed, 09 October 2013 |
7936 |
Thu, 10 October 2013 07:00 By: Eclipse User  |
general question about UML Testing Profile By: Eclipse User on Thu, 05 September 2013 |
7624 |
Tue, 01 October 2013 09:38 By: Eclipse User  |
Thread-safe UML CacheAdapter? By: Eclipse User on Mon, 16 September 2013 |
7993 |
Fri, 20 September 2013 02:56 By: Eclipse User  |
Package Merge Observation when using Stereotypes/Enumerations The UMLUtil.merge() seems to handle stereotype values which are enumerations incorrectly By: Eclipse User on Wed, 04 September 2013 |
4577 |
Mon, 09 September 2013 07:32 By: Eclipse User  |
Instructions to upload OMG UML Testing Profile ver.1.1 Step to use UTP in Eclipse By: Eclipse User on Thu, 24 January 2013 |
15691 |
Thu, 05 September 2013 09:32 By: Eclipse User  |
Extract a Subset of Communication Diagram Extract a Subset of Communication Diagram By: Eclipse User on Wed, 04 September 2013 |
5243 |
Wed, 04 September 2013 07:50 By: Eclipse User  |
Problem serialization of own UML ModelImpl By: Eclipse User on Mon, 19 August 2013 |
5077 |
Wed, 21 August 2013 14:35 By: Eclipse User  |
Error when using getValue(): Illegal argument exception By: Eclipse User on Fri, 09 August 2013 |
8769 |
Tue, 20 August 2013 08:20 By: Eclipse User  |
Ordering in Sequence Diagrams By: Eclipse User on Mon, 19 August 2013 |
3720 |
Mon, 19 August 2013 22:01 By: Eclipse User  |
Importing/Opening xmi file from OMG Importing/Opening xmi file By: Eclipse User on Fri, 09 August 2013 |
9476 |
Tue, 13 August 2013 12:58 By: Eclipse User  |
Simply API for saving UML2 models and associated Profile/Stereotype values By: Eclipse User on Tue, 30 July 2013 |
7822 |
Tue, 30 July 2013 13:30 By: Eclipse User  |
XMI attribute lost By: Eclipse User on Wed, 24 July 2013 |
7845 |
Mon, 29 July 2013 15:28 By: Eclipse User  |
Control and Object flow in Activity Model Flows do not appear in UML Model Editor By: Eclipse User on Mon, 29 July 2013 |
3768 |
Mon, 29 July 2013 07:58 By: Eclipse User  |
How to create programatically un object of given DataType By: Eclipse User on Thu, 25 July 2013 |
4265 |
Thu, 25 July 2013 07:22 By: Eclipse User  |
How to keep stereotypeApplications while moving an object By: Eclipse User on Mon, 22 July 2013 |
5220 |
Mon, 22 July 2013 02:45 By: Eclipse User  |
Does anyone know where I can get M2 model for UML2 (Show like a Class Diagram) By: Eclipse User on Thu, 27 June 2013 |
4889 |
Sun, 30 June 2013 00:01 By: Eclipse User  |
Reference beetween Package and class By: Eclipse User on Thu, 27 June 2013 |
4104 |
Thu, 27 June 2013 05:40 By: Eclipse User  |
what is the root for all UML models? By: Eclipse User on Tue, 25 June 2013 |
5298 |
Tue, 25 June 2013 12:45 By: Eclipse User  |
How to get "tagged values" from an attribute of class in UML2.0 By: Eclipse User on Thu, 13 June 2013 |
9446 |
Tue, 25 June 2013 12:18 By: Eclipse User  |
UML profile with OCL constraints on stereotypes By: Eclipse User on Thu, 24 March 2011 |
13302 |
Fri, 21 June 2013 15:03 By: Eclipse User  |
Opening UML meta-model using oclInEcore editor By: Eclipse User on Sat, 08 June 2013 |
12525 |
Tue, 11 June 2013 08:06 By: Eclipse User  |
Loading UML-Model with papyrus-profile applied By: Eclipse User on Tue, 14 May 2013 |
16469 |
Tue, 28 May 2013 02:23 By: Eclipse User  |
Problems with using the UML.ecore metamodel directly By: Eclipse User on Mon, 20 May 2013 |
6513 |
Tue, 21 May 2013 10:40 By: Eclipse User  |
How to write Eclipse UML2 XMI By: Eclipse User on Tue, 07 May 2013 |
7860 |
Thu, 09 May 2013 08:00 By: Eclipse User  |
how to migrate uml to new definitions migrate definitions and reduce profile size By: Eclipse User on Mon, 29 April 2013 |
5722 |
Tue, 07 May 2013 07:21 By: Eclipse User  |
