Home » Eclipse Projects » Papyrus for Real Time » Problem finishing the PingPong tutorial (Compilation errors in generated code.)
Re: Problem finishing the PingPong tutorial [message #1773588 is a reply to message #1773586] Fri, 29 September 2017 18:12 Go to previous messageGo to previous message
Ernesto Posse is currently offline Ernesto PosseFriend
Hmm... strange.
A couple of things:
1) can you type in the Cygwin terminal
echo $UMLRTS_ROOT
and report it here?
2) can you try regenerating by deleting the CDT project, and then right-click on the root model element (PingPong) and then selecting "(Re)Generate all code" and see if it gives you the same error?
3) what version of Java do you have?
4) can you go to Help->About Papyrus-RT->Installation Details, unfold Papyrus for Real-Time and expand the Version column to ensure that we see the full version numbers and post it here? Also post the contents of the Configuration tab.
[Updated on: Fri, 29 September 2017 18:24]
Report message to a moderator
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:Creating internal transition in UML-RT?
Next Topic:code generation time
Current Time: Sat Jun 06 15:24:03 GMT 2020
Powered by FUDForum. Page generated in 0.02190 seconds
