Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Issue with loading properties from a CDO resource in Library Example project
Issue with loading properties from a CDO resource in Library Example project [message #2635] |
Mon, 14 November 2005 07:44 |
Originally posted by: tvalence1.cox.net
Greetings,
I have been investigating an issue with populating a model with properties
from a CDO resource that has been persisted in MySql. I believe that I have
been able to reproduce a similar behavior with the Library Example project
using the latest code from CVS.
In this instance, the
org.eclipse.net4j.cdo.test.actions.LoadResourceAction.loadRe source method
succeeds in accessing and printing the name of the first author (Einstein),
but throws an exception when trying to access the second author (Dahl)
object from the library resource. The relevant code snippet and a debug
trace of LoadResourceAction's operation is attached for reference.
Note that an expansion of the persisted library resource using the Library
Model Editor works with no problems in my eClipse 3.1.0/JDK 1.5 development
environment.
Please advise on how I can resolve this issue. I can send additional
configuration and trace information if this can further define the problem.
Thanks!
= Ted
Re: Issue with loading properties from a CDO resource in Library Example project [message #2664 is a reply to message #2635] |
Mon, 14 November 2005 07:53 |
Sorry. The correct code snippet is in the updated attachment.
- Ted
"TVal" <tvalence1@cox.net> wrote in message
news:dl9f91$93j$1@news.eclipse.org...
> Greetings,
> have
> (Einstein),
> development
> environment.
> problem.
> Thanks!
> = Ted
Re: Issue with loading properties from a CDO resource in Library Example project [message #2697 is a reply to message #2664] |
Mon, 14 November 2005 10:33 |
Originally posted by: stepper.sympedia.de
Hi Ted,
You are right, I could also observe this issue with the library example
and the newest CDO version. It took me quite some while but I was able
to fix it. Please update to LATEST.
I really hope that I didn't break something else. If only I had time
to settle proper regression tests...
Cheers
/Eike
> - Ted
>>Greetings,
>>have
>>(Einstein),
>>development
>>environment.
>>problem.
>>Thanks!
>>= Ted
Re: Issue with loading properties from a CDO resource in Library Example project [message #2716 is a reply to message #2697] |
Tue, 15 November 2005 07:04 |
Thanks for the near real-time response Eike.
The LATEST version of the CDO implementation resolved the reported issue
with the Library Example.
Moreover, I also verified that this update also resolved the issues that I
previously observed in the navigation and retrieval of properties in my
application's model. :)
Please let me know if I can be of assistance in setting up your regression
test suites.
Cheers.
- Ted
"Eike Stepper" <stepper@sympedia.de> wrote in message
news:dl9p51$m6u$1@news.eclipse.org...
> Hi Ted,
> Cheers
> /Eike
>> - Ted
>>>Greetings,
>>>properties
>>>have
>>>project
>>>(Einstein),
>>>Library
>>>development
>>>environment.
>>>problem.
>>>Thanks!
>>>= Ted
Re: Issue with loading properties from a CDO resource in Library Example project [message #4091 is a reply to message #2716] |
Tue, 15 November 2005 09:55 |
Just evaluating my brand new and throughput optimized "Multi Threaded Brain 2.1" ;-)
That's good to hear!
> test suites.
That's even better to hear ;-)
The most important things to test (by degrading importance) are:
1) Create and/or manipulate various model instances, commit to database and check db state.
2) Prepare various db states, load models from database and check the models.
3) Combinations of 1) + 2) with a focus on InvalidationNotifications in multi client setups.
What do you think?
Cheers
/Eike
Re: Issue with loading properties from a CDO resource in Library Example project [message #4147 is a reply to message #4091] |
Wed, 16 November 2005 16:21 |
Eike,
The list looks like a good start.
Did you have a particular set of models (e.g. Library Example) in mind for
the regression testing?
Thanks.
= Ted
news:dlcb9h$idg$1@news.eclipse.org...
> Brain 2.1" ;-)
>> I previously observed in the navigation and retrieval of properties in my
>> regression test suites.
> and check db state.
> models.
> What do you think?
> Cheers
> /Eike
Re: Issue with loading properties from a CDO resource in Library Example project [message #4218 is a reply to message #4147] |
Thu, 17 November 2005 07:50 |
No. I think we can use model(s) that are specifically designed to support the test cases.
They should enable the test logic to use all the EMF features that are supported by CDO.
In general we can assume, that each method of the generated model API that leads to
notification sending should be tested with all kinds of argument vales and in various
call orders.
I'm quite sure that we will have some different sorts of test environment. For example
item 3 of my previous scenario list is the only one with multiple clients, the test client
will have to have very fine control over thread sync.
Btw. I will leave for a 2 weeks vacation tomorrow and there will (intentionally ;-) )
be no phone or email. After I returned I can start to think about these environmental
test aspects.
If you are willing you could start to specify the test cases from a pure CDO client's
point of view. In some simple pseudo notation, just to see the requirements of the
needed test framework:
PRECONDITION/EXECUTION
1. create resource R1
2. create object of class X (described somewhere else),
populate it with (a=?, ...)
add it to R1 contents
3. commit
EXPECTED RESULT
- describe client side process state (if applicable)
- describe server side process state (if applicable)
- describe server side database state (if applicable)
Something like that would already be a great deal ;-)
If you have questions, I'm still here today...
Cheers
/Eike
CDO Regression Testing [message #4289 is a reply to message #4218] |
Thu, 17 November 2005 19:15 |
Eike,
Can we draft a test strategy for mapping out the different aspects of the
test effort?
Such a document could help us coordinate a distributed test effort while
ensuring that we satisfy test coverage requirements for a well-defined
scope. The strategy doc would also provide the context and standards for
developing test cases and supporting infrastructure/tools.
The eClipse TPTP project has a nice test strategy document that we could
potentially tailor to suit our needs for CDO testing.
http://eclipse.org/tptp/home/documents/process/TPTP_Testing_ Strategy.html
Your thoughts?
Thanks, and have a great vacation! :)
- Ted
news:dlhcp2$i6h$1@news.eclipse.org...
>> for the regression testing?
> the test cases.
> supported by CDO.
> leads to
> in various
> call orders.
> For example
> the test client
> environmental
> test aspects.
> CDO client's
> requirements of the
> 3. commit
> EXPECTED RESULT
> Cheers
> /Eike
Re: CDO Regression Testing [message #7369 is a reply to message #4289] |
Thu, 15 December 2005 10:15 |
TVal schrieb:
> Eike,
> test effort?
There's nothing against it, in general.
I've had a look at the document you referred to below and I
got a little bit the impression that TPTP is bigger than CDO ;-)
What about the following:
- I start to gather some (test) requirements from a very technical point of view,
such as test environments (network, db, ...), test code generation (merlin),
test automation and the like.
- I leave it to you to take these snippets and combine them with appropriate
elements from the TPTP doc.
> Your thoughts?
> - Ted
Thanks ;-)
/Eike
Re: CDO Regression Testing [message #7390 is a reply to message #7369] |
Thu, 15 December 2005 17:18 |
Eike,
Sounds like a great approach.
I look forward to your technical test requirements.
Thanks.
- Ted
news:dnrfnf$6ss$1@news.eclipse.org...
> TVal schrieb:
>> Eike,
>> test effort?
> of view,
> (merlin),
> appropriate
>> Your thoughts?
>> - Ted
> Thanks ;-)
> /Eike
Re: Issue with loading properties from a CDO resource in Library Example project [message #561393 is a reply to message #2635] |
- Ted
> Greetings,
> have
> (Einstein),
> development
> environment.
> problem.
> Thanks!
> = Ted
Re: Issue with loading properties from a CDO resource in Library Example project [message #561412 is a reply to message #2664] |
Hi Ted,
Cheers
/Eike
> - Ted
>>Greetings,
>>have
>>(Einstein),
>>development
>>environment.
>>problem.
>>Thanks!
>>= Ted
Cheers
/Eike
http://www.esc-net.de
Re: Issue with loading properties from a CDO resource in Library Example project [message #561431 is a reply to message #2697] |
test suites.
Cheers.
- Ted
> Hi Ted,
> Cheers
> /Eike
>> - Ted
>>>Greetings,
>>>properties
>>>have
>>>project
>>>(Einstein),
>>>Library
>>>development
>>>environment.
>>>problem.
>>>Thanks!
>>>= Ted
Re: Issue with loading properties from a CDO resource in Library Example project [message #561451 is a reply to message #2716] |
> test suites.
What do you think?
Cheers
/Eike
Cheers
/Eike
Re: Issue with loading properties from a CDO resource in Library Example project [message #561472 is a reply to message #4091] |
Eike,
Thanks.
= Ted
> Brain 2.1" ;-)
> and check db state.
> models.
> What do you think?
> Cheers
> /Eike
Re: Issue with loading properties from a CDO resource in Library Example project [message #561493 is a reply to message #4147] |
call orders.
test aspects.
3. commit
EXPECTED RESULT
Cheers
/Eike
Cheers
/Eike
CDO Regression Testing [message #561514 is a reply to message #4218] |
Eike,
test effort?
Your thoughts?
- Ted
> the test cases.
> supported by CDO.
> leads to
> in various
> call orders.
> For example
> the test client
> environmental
> test aspects.
> CDO client's
> requirements of the
> 3. commit
> EXPECTED RESULT
> Cheers
> /Eike
Re: CDO Regression Testing [message #561988 is a reply to message #4289] |
TVal schrieb:
> Eike,
> test effort?
> Your thoughts?
> - Ted
Thanks ;-)
/Eike
Cheers
/Eike
Re: CDO Regression Testing [message #562034 is a reply to message #7369] |
Eike,
Thanks.
- Ted
> TVal schrieb:
>> Eike,
>> test effort?
> of view,
> (merlin),
> appropriate
>> Your thoughts?
>> - Ted
> Thanks ;-)
> /Eike
Current Time: Fri Apr 19 07:13:50 GMT 2024
Powered by FUDForum. Page generated in 0.02667 seconds
