Re: Migration to 0.9.0 documentation? [message #1614558 is a reply to message #1613728] |
Fri, 13 February 2015 10:22   |
Zoltan Ujhelyi Messages: 392 Registered: July 2015 |
thank you for pointing out these issues in our documentation. We believed, version 0.9 does not require special migration steps, and left out the migration guide deliberately, but I guess, we were wrong here.
1) The method was renamed to withResourceFiltered() that creates a copy of the configuration. This was done to avoid problematic cases when it called after an engine was initialized from the configuration, this configuration would be inconsistent with the correct settings.
On the other hand, this plain renaming was not a good idea. To help with the issue, I am putting back the old methods with a deprecation comment to use the old ones, and we will have a quick bugfix version where this change would be included.
2) This change was done to make IncQuery less EMF-dependent, and the concept of Scopes were introduced. EMF scopes created for the old versions can be created with new EMFScope(Notifier) call, and this can be added as a parameter. We have added a deprecation message to original on method to help migrating to the new version. Your code should be like
IncQueryEngine engine = IncQueryEngine.on(new EMFScope(resourceSet));
Did you have any other issues with the generic API that was not clear or needed documenting? We would be very grateful for finding these gaps in our documentation, and try to make it better.
Zoltán
FUDForum. Page generated in 0.02981 seconds
