Home » Eclipse Projects » DSDP - Target Management » How to use SDK to launch terminal window
Re: How to use SDK to launch terminal window [message #30537 is a reply to message #30430] |
Tue, 30 December 2008 01:53 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Hi Wendy,
If you use the RSE-Terminals integration, it should be possible
to send an Eclipse Command (the equivalent of a keystroke). The
corresponding handler is declared in
org.eclipse.rse.terminals.ui/plugin.xml
looking at the handler's code should help.
If you want to use the plain TM-Terminal, the code for opening
it programmatically is in the works but has not yet been
committed (it will be committed soon). For details, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=185348
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Wendy Zheng wrote:
> Can someone show me how to use RSE SDK to launch the terminal window
> programmally? I installed RSE 3.0.1
> Can I use org.eclipse.rse.internal.services.terminals package?
> How do I get ITerminalService handle from program?
> Great thanks !
> Wendy
Re: How to use SDK to launch terminal window [message #32586 is a reply to message #32170] |
Mon, 02 March 2009 17:29 |
Hi Wendy,
sorry but the code didn't make it into M5. For details, please see the
bug. When you create a bugzilla account, you can also register for CC
on the bug, so you'll get notified when anything changes.
Wendy Zheng wrote:
> Hi Martin,
> Do you have sample code to show how to use tm.terminal API (3.1M5 build)
> to launch a terminal window?
> I am trying to launch a terminal window for a emulation device (unix
> process) in the remote host, to run CLI commands in terminal window.
> Instead of launching terminal view tab through RSE, can I invoke
> TM-terminal API directly here?
> Great thanks.
> Regards,
> Wendy
Re: How to use SDK to launch terminal window [message #578256 is a reply to message #30430] |
Hi Wendy,
Wendy Zheng wrote:
> Great thanks !
> Wendy
Re: How to use SDK to launch terminal window [message #579416 is a reply to message #32170] |
Hi Wendy,
Wendy Zheng wrote:
> Hi Martin,
> Great thanks.
> Regards,
> Wendy
Current Time: Fri Apr 26 00:39:47 GMT 2024
Powered by FUDForum. Page generated in 0.03659 seconds
