Found JUnit4 plugin, but can't install it! [message #303342] |
Fri, 12 May 2006 13:46 |
Originally posted by: marc.flores.baesystems.com
So I found a JUnit4 plugin (it's actually 3 plugins I guess) for Eclipse
3.1.2, but I can not figure out how to install it. Does anyone know?
I've tried to just drop the 3 folders into the Eclipse plugin folder, but
that didn't do anything.
I've also tried to do the install procedure for local site and archive
using:
Help --> Software Updates --> Find and Install
The download does not have any install directions, install executable or a
configuration that Eclipse seems to recognize as a "site".
Download page:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=102632
Download zip:
https://bugs.eclipse.org/bugs/attachment.cgi?id=34259
Contents:
new-plugins.zip (zip archive)
plugins (folder)
org.eclipse.jdt.junit4 (folder)
org.eclipse.jdt.junit4.runtime (folder)
org.junit.v4 (folder)
Re: Found JUnit4 plugin, but can't install it! [message #303343 is a reply to message #303342] |
Fri, 12 May 2006 13:59 |
Originally posted by: eclipse.bettsockentraeger.de
Have you done a clean (-clean option on commandline) restart of Eclipse
after having dropped the plugins into the plugi folder?
> but that didn't do anything.
> using:
> a configuration that Eclipse seems to recognize as a "site".
> Download page:
> Download zip:
> Contents:
> plugins (folder)
Re: Found JUnit4 plugin, but can't install it! [message #303347 is a reply to message #303343] |
Fri, 12 May 2006 15:28 |
No, but I just tried it, and I still don't see any change.
Maybe I don't know what to look for? I do a File --> New --> Junit Test
Case, and it looks like a JUnit3 type gui.
Do I need to do anyting in the menu items below to activate JUnit 4, or
even deactivate JUnit3?
Window --> Preferences --> Java --> JUnit
or
Window --> Preferences --> Java --> Build Path --> Classpath Variables
(tried to change JUNIT_HOME, but keeps reverting to JUnit3 on restart)
Thanks!
Re: Found JUnit4 plugin, but can't install it! [message #303356 is a reply to message #303355] |
Fri, 12 May 2006 16:57 |
That is an interim release though, not an official release right?
Are these types of releases safe to use?
How easy is it to keep up with all of the incremental non-official
releases?
In general shouldn't a user wait until the official full release?
I'm new to Eclipse so I don't know much about it. Thanks for any help.
FUDForum. Page generated in 0.03408 seconds
