Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » installing Javascript IDE with integration build
installing Javascript IDE with integration build [message #30402] Thu, 21 August 2008 04:54 Go to next message
since I'm using the PDT 2.0 I had to install the integration build of
DLTK by putting it into a local directory and add a local update site.
I don't see any javascript ide in the update dialog of eclipse, so i
guess I should download the zip from the dltk download site, but will it
work with the integration build?
Or, is there a better way to install it?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: installing Javascript IDE with integration build [message #30437 is a reply to message #30402] Thu, 21 August 2008 11:52 Go to previous messageGo to next message
Hi Lorenzo,
You can use update site of the last integration build
http://download.eclipse.org/technology/dltk/updates-dev/1.0/
Or you can manually download .zip fles from the integration builds. If
you don't want to install All-in-1 bundle you should download only "Core
Frameworks" and "Javascript IDE" components. Eclipse 3.4 supports
loadings plugins from the special "dropins" folder, so now it is much
easier to manually manage installed plugins - create e.g. DLTK_1_0
subfolder and unzip the downloaded files into it.
Alex
Lorenzo Bettini wrote:
> Hi
> thanks in advance
> Lorenzo
Re: installing Javascript IDE with integration build [message #30471 is a reply to message #30437] Sat, 23 August 2008 13:12 Go to previous messageGo to next message
I had actually used a local directory for PDT and DLTK, but I feared
that then it would not check the remote update site anymore, am I right?
With dropins this would not happen?
thanks again
Lorenzo
Alex Panchenko wrote:
> Hi Lorenzo,
> Regards,
> Alex
>> Hi
>> it work with the integration build?
>> thanks in advance
>> Lorenzo
Re: installing Javascript IDE with integration build [message #30542 is a reply to message #30471] Sun, 24 August 2008 23:41 Go to previous message
It depends on what URLs are specified in the features - I have not
checked PDT, but in DLTK there are URLs of the update site of the
released versions.
IMHO that is correct since your most probably don't want to
automatically update to the next integration builds - some of them are
not stable, etc.
Alex
> Hi
> thanks again
> Lorenzo
>> Hi Lorenzo,
>> "Core Frameworks" and "Javascript IDE" components. Eclipse 3.4
>> supports loadings plugins from the special "dropins" folder, so now it
>> is much easier to manually manage installed plugins - create e.g.
>> DLTK_1_0 subfolder and unzip the downloaded files into it.
>> Regards,
>> Alex
>>> Hi
>>> thanks in advance
>>> Lorenzo
Previous Topic:[BUILD] R1.0-I
Next Topic:Setting up Libraries
Current Time: Tue Mar 25 21:38:50 EDT 2025
Powered by FUDForum. Page generated in 0.25186 seconds
