Home » Eclipse Projects » Sirius » Relation-based Edge Sources
Relation-based Edge Sources [message #1611883] |
Wed, 11 February 2015 17:22 |
Robbie Simpson Messages: 7 Registered: February 2015 |
Hi all,
I am working on a relatively simple Sirius project. I have several different types of nodes, linked by some M-N cardinality Relation-Based Edges which are Bi-Directional. I have implemented a simple boolean enabled flag on the nodes, and want to use conditional styles on the edges to indicate which edges are linked to disabled nodes.
For the targets of the edges, this is easy - I can just do [self.enabled=false/], because self on the edges resolves to the actual semantic element. However, I can see no way to determine if the source of the edge is disabled. There does not seem to be anyway to identify the edge using Acceleo, and so I can't determine which source node corresponds to the current edge.
Is their some clever trick I am missing, or are Relation-Based Edges not really intended for bi-directional relationships ? (perhaps I should convert my bi-directional edges to element edges instead?)
Robbie
Re: Relation-based Edge Sources [message #1614445 is a reply to message #1611883] |
Fri, 13 February 2015 08:45 |
> Hi all,
Hi Robbie,
See my comments below.
The target is accessible by following the relation on which the edge is
based. The Relation Based Edge context is the semantic source on which
the edge Source Mapping is defined.
For instance, if I define an edge based on the "eSuperTypes" relation
(between two EClass), the Target Finder Expression is "[eSuperTypes/]".
If I decide to have a particular edge style if the source is "abstract"
(such as your "enabled" flag), the Conditional Style Predicate
Expression will be "[abstract/]" because the context is the source.
> Cheers,
> Robbie
Florian - Obeo
Need professional services for Sirius?
Re: Relation-based Edge Sources [message #1614786 is a reply to message #1611883] |
Fri, 13 February 2015 13:52 |
Thanks - I had confused myself by having edge arrows that point the `wrong` way, so I got my targets and sources reversed.
However, I still have problems due to the many-to-many nature of my relationships. My Target Finder Expression evaluates to a list, which contains all elements linked to the source by that relationship, not just the one associated with the current edge.
For example, in my case I have operations that require resources, and so the edge is operation -> resource. On my edge, I can do [requiredResources], but this will give me a list of two or more resources and so I cannot tell which resource corresponds to the current edge.
Thanks again,
Robbie
Re: Relation-based Edge Sources [message #1619510 is a reply to message #1614786] |
Mon, 16 February 2015 16:32 |
Sirius will create one edge per found element. But for relation based
edge, the semantic element of those edges will be their source element.
(so with your m-n cardinality, you will have the same issue if you
"revert" the mapping, which would have been a clever trick with a 1-n
cardinality)
> edge.
Yes, you can: you edge is a DEdge (Sirius internal metamodel), and has a
sourceNode/getSourceNode() and a targetNode/getTargetNode() (metadel
reference / corresponding java method) which will be a
DSemanticDecorator with a semantic target/getTarget().
So from your current DEdge, in a mtl request or a java service you can
retrieve the sourceNode and targetNode semantic element and identify
which Operation/Resource couple is represented by an edge.
Then you will have to use different variables available in interpreted
expression of mapping/style/tools.
> Thanks again,
> Robbie
Maxime - Obeo
Maxime Porhel - Obeo
Current Time: Thu Apr 25 15:16:19 GMT 2024
Powered by FUDForum. Page generated in 0.03620 seconds
