Home » Eclipse Projects » OM2M » MQTT?(is it already there?)
MQTT? [message #1611760] Wed, 11 February 2015 15:50 Go to next message
Massimo Vecchio is currently offline Massimo VecchioFriend
Hi folks,
just wondering if the current available source of Om2m comes already with MQTT protocol support.
If not, how difficult would it be to integrate the Moquette project that already comes bundled for OSGI? Reading from the readme in github (sorry, I cannot post external links) the authors say: "Starting from version 0.6 Moquette is OSGi compliant". The question is: how difficult is its integration into Om2m (given that I'm not a software guru)?
Thx
M
Re: MQTT? [message #1612803 is a reply to message #1611760] Thu, 12 February 2015 07:58 Go to previous messageGo to next message
Andrea Selva is currently offline Andrea SelvaFriend
Hi Massimo,
I'm Andrea Selva the committer of Moquette MQTT broker. It should be quite easy, just drop the bundle and it start itself, the activator class do the start and stop of the service. But from version 0.7-SNAPSHOT I've changed some dependencies and I'm experiencing some problems with OSGi bundling,I'll fix for the final release.
Andrea
Re: MQTT? [message #1621023 is a reply to message #1612803] Tue, 17 February 2015 16:04 Go to previous messageGo to next message
great Andrea!
I will give it a try asap...in case of problems, would you be available to help? I repeat: I'm quite noob in advanced java... Embarrassed
thanks,
Massimo
Re: MQTT? [message #1747334 is a reply to message #1612803] Sat, 12 November 2016 13:37 Go to previous messageGo to next message
Asad Khan is currently offline Asad KhanFriend
Hi Andrea
I am completely new to Java/OSGi , can you please give some tipse how to add MQTT broker to OM2M ?
Asad
Re: MQTT? [message #1747335 is a reply to message #1612803] Sat, 12 November 2016 13:39 Go to previous messageGo to next message
Hi Andrea
I am completely new to Java/OSGi , can you please give some tips how to add MQTT broker to om2m ?
Asad
Re: MQTT? [message #1775262 is a reply to message #1747335] Fri, 27 October 2017 03:51 Go to previous messageGo to next message
Umar Farooq is currently offline Umar FarooqFriend
Hi Asad/Andrea,
I have the same question Asad has, how to add MQTT broker to om2m?
Re: MQTT? [message #1775922 is a reply to message #1775262] Wed, 08 November 2017 09:46 Go to previous message
Xurxo Legaspi is currently offline Xurxo LegaspiFriend
Hi all,
as far as I'm concerned, the MQTT broker is NOT implemented/included in om2m.
Instead, and following the docs: https://wiki.eclipse.org/OM2M/one/MQTT_Binding
what you should do is to deploy the MQTT broker separetely (i.e. mosquitto) and CONFIGURE the om2m framework to connect to it.
Hope it helps,
Previous Topic:Notification over MQTT
Next Topic:Issue after cloning OM2M v1.1
Current Time: Thu Feb 20 14:34:36 GMT 2020
Powered by FUDForum. Page generated in 0.02007 seconds
