No merging of model fragments [message #1610122] |
Tue, 10 February 2015 15:19 |
Dear experts,
I am trying some very basic toy example of plugging some fragments or processors to my foo application.
I am pretty sure -- triple checked, 6 eyes -- I did all the darn things good: ID, feature names, extensions, required plugins, and so on.
Still, no fragment is loaded (nor as direct plugin nor as part of a feature).
No complaints from the log console.
Before some more aggressive debugging task force, does anybody have a clue of why this is happening?
I am hereby attaching the related plugins in case some Good Samaritan is curious to inspect the issue.
appreciated,
-Piero
Attachment: plugins.zip
(Size: 19.24KB, Downloaded 97 times)
[Updated on: Tue, 10 February 2015 17:53] Report message to a moderator
Re: No merging of model fragments [message #1611408 is a reply to message #1610122] |
Wed, 11 February 2015 10:46 |
Jonas Helming Messages: 699 Registered: July 2009 |
Have you validated your fragment bundle is part of the run config?
Have your tried to clear the workspace as well as the OSGi config area?
Am 10.02.2015 um 16:19 schrieb Piero Campalani:
> Dear experts,
> feature).
> What I get from the log console is (apart from nothing else):
> !ENTRY org.eclipse.e4.ui.workbench 1 0 2015-02-10 16:12:26.551
> !MESSAGE Nothing to merge for
> "platform:/plugin/org.eclipse.e4.tools.emf.ui/fragment.e4xmi"
> (twice)
> appreciated,
> -Piero
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: No merging of model fragments [message #1611852 is a reply to message #1611408] |
Wed, 11 February 2015 16:58 |
The fragment stitching is handled by the org.eclipse.e4.ui.internal.workbench.ModelAssembler class. Feel free to open a bug if you see any improvements for logging errors that would have helped you diagnose the situation.
Brian.
Re: No merging of model fragments [message #1612893 is a reply to message #1611852] |
Thu, 12 February 2015 09:13 |
Jonas, Brian,
thanks for your replies.
Eventually, it was a matter of re-creating a run configuration for the product.
I still had to walk through the idea that running via key-binding (hence run configuration) is not as launching via the product.
-Piero
FUDForum. Page generated in 0.03016 seconds
