Home » Modeling » Papyrus » Customisation of "properties views"
Customisation of "properties views" [message #1608446] Mon, 09 February 2015 14:22 Go to next message
Philip LOUCOPOULOS is currently offline Philip LOUCOPOULOSFriend
Member
To be clear, I am battling to understand how to customise the properties views of Papyrus.
How to create a specific tab, as presented in the attached slide ?
Thanks for your help !
Philipindex.php/fa/20770/0/
Re: Customisation of "properties views" [message #1690338 is a reply to message #1608446] Thu, 26 March 2015 16:23 Go to previous messageGo to next message
Member
Does anybody know how this customization works ??
Thank you !
Philip
Re: Customisation of "properties views" [message #1690411 is a reply to message #1690338] Fri, 27 March 2015 08:49 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
Hi Philip,
The customization of the properties view is documented in the Papyrus User Guide in Eclipse Help Contents (Help > Help Contents > Papyrus Guide > User Guide > Properties view customization)
That should be a good starting point. If you get stuck at any point, please feel free to ask for additional details
Camille
Camille Letavernier
Re: Customisation of "properties views" [message #1690635 is a reply to message #1690411] Mon, 30 March 2015 09:17 Go to previous messageGo to next message
Lola Masson is currently offline Lola MassonFriend
I don't find how to separate the applied stereotype properties like shown on the picture. In the customization view I find "applied stereotypes" si I can have the same widget than the one on the first picture, but I can't have the "Description", "Id" and "Importance"
Thank you,
Lola
Re: Customisation of "properties views" [message #1690649 is a reply to message #1690635] Mon, 30 March 2015 11:48 Go to previous messageGo to next message
The SRML tab in the example has been generated from the SRML profile (And slightly modified, to also display the "Name" property from UML)
This has been done through the Wizard "New > Papyrus > Properties view configuration", then deployed as a plug-in
Camille
Camille Letavernier
Re: Customisation of "properties views" [message #1690654 is a reply to message #1690649] Mon, 30 March 2015 12:28 Go to previous message
This works,
Thanks !
Lola
[Updated on: Mon, 30 March 2015 14:11]
Report message to a moderator
Previous Topic:Problem with installation of MOKA
Next Topic:Instantiation of blocks does not show ports in Papyrus
Current Time: Thu Jul 29 03:54:41 GMT 2021
Powered by FUDForum. Page generated in 0.02476 seconds
