[buckminster-dev] Project can't be build until its prerequisite is build [message #30195] |
Thu, 15 January 2009 12:57 |
suresh inavolu Messages: 3 Registered: July 2009 |
--0-1613023340-1232024232=:19683
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: quoted-printable
I getting the following exception while building the project
However the plugin com.springsource.javax.xml.stream is a binary plugin and=
is not required to build.
It is mentioned in the search path as mutable=3D"false" and source=3D"false=
Is there anything I am missing here?
Trace:
=A0=A0=A0=A0 [java] org.eclipse.core.runtime.CoreException: The project can=
not be built until its prerequisite com.springsource.javax.xml.stream is bu=
ilt. Cleaning and building all projects is recommended
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.core.internal.acto=
r.AbstractBuildIntegrationActor.internalPerform(AbstractBuil dIntegrationAct=
or.java:53)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.core.actor.Abstrac=
tActor.perform(AbstractActor.java:195)
r.PerformManager.perform(PerformManager.java:299)
r.PerformManager.perform(PerformManager.java:343)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.core.commands.Perf=
orm.internalRun(Perform.java:192)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.core.commands.Work=
spaceCommand.run(WorkspaceCommand.java:95)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.cmdline.AbstractCo=
mmand.basicRun(AbstractCommand.java:52)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.cmdline.Headless.r=
un(Headless.java:295)
un(Headless.java:229)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.cmdline.Headless.s=
tart(Headless.java:304)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.equinox.internal.app.EclipseAp=
pHandle.run(EclipseAppHandle.java:193)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.core.runtime.internal.adaptor.=
EclipseAppLauncher.runApplication(EclipseAppLauncher.java:11 0)
EclipseAppLauncher.start(EclipseAppLauncher.java:79)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.core.runtime.adaptor.EclipseSt=
arter.run(EclipseStarter.java:386)
arter.run(EclipseStarter.java:179)
=A0=A0=A0=A0 [java] =A0=A0=A0 at sun.reflect.NativeMethodAccessorImpl.invok=
e0(Native Method)
e(NativeMethodAccessorImpl.java:39)
=A0=A0=A0=A0 [java] =A0=A0=A0 at sun.reflect.DelegatingMethodAccessorImpl.i=
nvoke(DelegatingMethodAccessorImpl.java:25)
=A0=A0=A0=A0 [java] =A0=A0=A0 at java.lang.reflect.Method.invoke(Method.jav=
a:585)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.equinox.launcher.Main.invokeFr=
amework(Main.java:549)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.equinox.launcher.Main.basicRun=
(Main.java:504)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.equinox.launcher.Main.run(Main=
..java:1236)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.equinox.launcher.Main.main(Mai=
n.java:1212)
Suresh
=0A=0A=0A
Content-Type: text/html; charset=us-ascii
<table cellspacing="0" cellpadding="0" border="0" ><tr><td valign="top" style="font: inherit;">Hi,<br><br>I getting the following exception while building the project<br><br>However the plugin com.springsource.javax.xml.stream is a binary plugin and is not required to build.<br><br>It is mentioned in the search path as mutable="false" and source="false".<br><br>Is there anything I am missing here?<br><br>-----<br>Trace:<br> [java] org.eclipse.core.runtime.CoreException: The project cannot be built until its prerequisite com.springsource.javax.xml.stream is built. Cleaning and building all projects is recommended<br> [java] at org.eclipse.buckminster.core.internal.actor.AbstractBuildInt egrationActor.internalPerform(AbstractBuildIntegrationActor. java:53) <br> [java] at
org.eclipse.buckminster.core.actor.AbstractActor.perform(Abs tractActor.java:195) <br> [java] at org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:299) <br> [java] at org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:343) <br> [java] at org.eclipse.buckminster.core.commands.Perform.internalRun(Pe rform.java:192) <br> [java] at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:95) <br> [java] at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:52) <br> [java] at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:2 95) <br> [java]
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:2 29) <br> [java] at org.eclipse.buckminster.cmdline.Headless.start(Headless.java :304) <br> [java] at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193) <br> [java] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110) <br> [java] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79) <br> [java] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386) <br> [java] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179) <br> [java] at
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<br> [java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39) <br> [java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25) <br> [java] at java.lang.reflect.Method.invoke(Method.java:585)<br> [java] at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549) <br> [java] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)<br > [java] at org.eclipse.equinox.launcher.Main.run(Main.java:1236)<br> [java] at org.eclipse.equinox.launcher.Main.main(Main.java:1212)<br><br >Thanks<br>Suresh<br></td></tr></table><br>
--0-1613023340-1232024232=:19683--
FUDForum. Page generated in 0.04187 seconds
