CDT under Ubuntu Gnome, lots of errors [message #1605652] |
Sat, 07 February 2015 17:29 |
Andreas Chen Messages: 1 Registered: February 2015 |
Junior Member |
I recently moved from Ubuntu Unity to Gnome. However Eclipse-CDT does not work properly. Some make projects involving CUDA compiles well in Unity, but fails in Gnome.
The same project compiles and runs perfectly under command line in Ubuntu Gnome, so I believe a little tweak is needed for CDT. I would appreciate for any suggestions.
Errors are like:
/usr/bin/ld: warning: libcudart.so.6.5, needed by //usr/local/lib/libafcuda.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libcublas.so.6.5, needed by //usr/local/lib/libafcuda.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libcufft.so.6.5, needed by //usr/local/lib/libafcuda.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libnvvm.so.2, needed by //usr/local/lib/libafcuda.so, not found (try using -rpath or -rpath-link)
//usr/local/lib/libafcuda.so: undefined reference to `cublasZgemv_v2'
//usr/local/lib/libafcuda.so: undefined reference to `cublasCgemm_v2'
//usr/local/lib/libafcuda.so: undefined reference to `nvvmCompileProgram'
//usr/local/lib/libafcuda.so: undefined reference to `nvvmGetCompiledResultSize'
//usr/local/lib/libafcuda.so: undefined reference to `cudaGetDeviceCount'
//usr/local/lib/libafcuda.so: undefined reference to `nvvmGetCompiledResult'
//usr/local/lib/libafcuda.so: undefined reference to `cufftExecZ2Z'
//usr/local/lib/libafcuda.so: undefined reference to `cudaFree'
//usr/local/lib/libafcuda.so: undefined reference to `cudaMallocHost'
//usr/local/lib/libafcuda.so: undefined reference to `cudaGetDeviceProperties'
//usr/local/lib/libafcuda.so: undefined reference to `cudaPeekAtLastError'
//usr/local/lib/libafcuda.so: undefined reference to `cudaSetupArgument'
//usr/local/lib/libafcuda.so: undefined reference to `cudaGetDevice'
//usr/local/lib/libafcuda.so: undefined reference to `cudaMemset'
//usr/local/lib/libafcuda.so: undefined reference to `__cudaRegisterFunction'
//usr/local/lib/libafcuda.so: undefined reference to `cublasDgemm_v2'
//usr/local/lib/libafcuda.so: undefined reference to `cublasZgemm_v2'
//usr/local/lib/libafcuda.so: undefined reference to `cudaFuncGetAttributes'
//usr/local/lib/libafcuda.so: undefined reference to `cublasSgemv_v2'
//usr/local/lib/libafcuda.so: undefined reference to `cublasCreate_v2'
//usr/local/lib/libafcuda.so: undefined reference to `cudaFreeHost'
//usr/local/lib/libafcuda.so: undefined reference to `cudaConfigureCall'
//usr/local/lib/libafcuda.so: undefined reference to `cufftExecC2C'
//usr/local/lib/libafcuda.so: undefined reference to `cufftPlanMany'
//usr/local/lib/libafcuda.so: undefined reference to `cudaRuntimeGetVersion'
//usr/local/lib/libafcuda.so: undefined reference to `nvvmGetProgramLogSize'
//usr/local/lib/libafcuda.so: undefined reference to `cublasCgemv_v2'
//usr/local/lib/libafcuda.so: undefined reference to `nvvmCreateProgram'
//usr/local/lib/libafcuda.so: undefined reference to `nvvmGetProgramLog'
//usr/local/lib/libafcuda.so: undefined reference to `cublasSgemm_v2'
//usr/local/lib/libafcuda.so: undefined reference to `cudaMemcpyToSymbol'
//usr/local/lib/libafcuda.so: undefined reference to `cudaSetDevice'
//usr/local/lib/libafcuda.so: undefined reference to `cublasSdot_v2'
//usr/local/lib/libafcuda.so: undefined reference to `cudaDeviceSynchronize'
//usr/local/lib/libafcuda.so: undefined reference to `cudaLaunch'
//usr/local/lib/libafcuda.so: undefined reference to `nvvmAddModuleToProgram'
//usr/local/lib/libafcuda.so: undefined reference to `__cudaUnregisterFatBinary'
//usr/local/lib/libafcuda.so: undefined reference to `cudaMemcpyFromSymbol'
//usr/local/lib/libafcuda.so: undefined reference to `cublasDestroy_v2'
//usr/local/lib/libafcuda.so: undefined reference to `__cudaRegisterFatBinary'
//usr/local/lib/libafcuda.so: undefined reference to `nvvmDestroyProgram'
//usr/local/lib/libafcuda.so: undefined reference to `cudaMalloc'
//usr/local/lib/libafcuda.so: undefined reference to `cudaMemcpy'
//usr/local/lib/libafcuda.so: undefined reference to `cublasDgemv_v2'
//usr/local/lib/libafcuda.so: undefined reference to `__cudaRegisterVar'
//usr/local/lib/libafcuda.so: undefined reference to `cudaGetErrorString'
//usr/local/lib/libafcuda.so: undefined reference to `cublasDdot_v2'
//usr/local/lib/libafcuda.so: undefined reference to `cufftDestroy'
collect2: error: ld returned 1 exit status
FUDForum. Page generated in 0.03639 seconds
