Unable to find plugin ... - CoreException - FeatureBuildGenerator [message #301350] |
Wed, 29 March 2006 11:25 |
Lukasz Olek Messages: 10 Registered: July 2009 |
I am trying to use PDE Build plugin and I have some problems doing
it. PDE build is constantly throwing CoreExcpetion. It is thrown by
FeatureBuildGenerator class, while trying to genarate build.xml files
for each plugin.
generateScript:
Property ${outputUpdateJars} has not been set
Property ${archivesFormat} has not been set
Property ${forceContextQualifier} has not been set
[ant] Exiting
E:\eclipse\plugins\org.eclipse.pde.build_3.1.0\scripts\gener icTargets.xml.
[ant] Exiting
E:\ucworkbench.build\org.ucworkbench.build\customTargets.xml .
[antcall] Exiting
E:\eclipse\plugins\org.eclipse.pde.build_3.1.0\scripts\build .xml.
BUILD FAILED
E:\eclipse\plugins\org.eclipse.pde.build_3.1.0\scripts\build .xml:23: The
following error occurred while executing this line:
E:\eclipse\plugins\org.eclipse.pde.build_3.1.0\scripts\build .xml:63: The
E:\ucworkbench.build\org.ucworkbench.build\customTargets.xml :8: The
E:\eclipse\plugins\org.eclipse.pde.build_3.1.0\scripts\gener icTargets.xml:67:
org.eclipse.core.runtime.CoreException: Unable to find plug-in:
org.ucworkbench_1.0.5. Please check the error log for more details.
at
org.apache.tools.ant.ProjectHelper.addLocationToBuildExcepti on(ProjectHelper.java:539)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:384)
at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:107)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
at org.apache.tools.ant.Task.perform(Task.java:364)
at org.apache.tools.ant.Target.execute(Target.java:341)
at org.apache.tools.ant.Target.performTasks(Target.java:369)
It is always the same message: Unable to find plug-in:
The strange thing is that all the plugins and features are properly
fetched from CVS. All needed files are copied on local disk, so I don't
know why PDE build cannot locate that missing plugin. Moreover some
plugins have successfuly passed the phase of generating build.xml files
but it always stops with error on this one (org.ucworkbench).
I tried to debug the process of building in Eclipse and I found out that
the error ocurrs beacuse BundleDescription for this plugin is not resolved.
Thanks for all kind of help.
Maciek Mazur
FUDForum. Page generated in 0.01805 seconds
