Importing repositories from previous version [message #30055] |
Wed, 06 August 2008 09:29 |
Originally posted by: jdchourio.communi.tv
Hello:
Sorry if this has been asked before but I couldn't find anything with the
search engine.
Is it possible to import repositories list from my eclipse-3.2's
workspace? Or should I add again all the repositories?
Is there anyway to read the file
workspace\.metadata\.plugins\org.polarion.team.svn.core\.svn Repositories?
Thanks in advance,
Javier
Re: Importing repositories from previous version [message #30379 is a reply to message #30343] |
Wed, 06 August 2008 14:47 |
Right now I can't reproduce the error. After several tries, I decided
to recreate the workspace.
Anyway I can rescue some information from the log files. When I did as
indicated in the migration instructions, the attached message appeared.
Javier
Message:
!ENTRY org.eclipse.team.svn.core.svnnature 4 0 2008-08-06 15:56:03.375
!MESSAGE SVN: '0x00400200: Transfer Settings' operation finished with error
!SUBENTRY 1 org.eclipse.team.svn.core.svnnature 4 0 2008-08-06 15:56:03.375
!MESSAGE Cannot convert repositories information files.
!STACK 0
java.io.StreamCorruptedException
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java :1332)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java: 348)
at
org.eclipse.team.svn.core.svnstorage.AbstractSVNStorage.load LocationsFromFile(AbstractSVNStorage.java:548)
at
org.eclipse.team.svn.core.svnstorage.AbstractSVNStorage.init ializeImpl(AbstractSVNStorage.java:402)
at
org.eclipse.team.svn.core.svnstorage.SVNRemoteStorage.initia lize(SVNRemoteStorage.java:164)
at
org.eclipse.team.svn.ui.debugmail.MigrateToEclipse$ConvertRe positoryFiles.runImpl(MigrateToEclipse.java:199)
at
org.eclipse.team.svn.core.operation.AbstractActionOperation. run(AbstractActionOperation.java:76)
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT ask(ProgressMonitorUtility.java:103)
at
org.eclipse.team.svn.core.operation.CompositeOperation.runIm pl(CompositeOperation.java:94)
at
at
org.eclipse.team.svn.core.operation.LoggedOperation.run(Logg edOperation.java:37)
at
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT askExternal(ProgressMonitorUtility.java:89)
at
org.eclipse.team.svn.ui.utility.DefaultCancellableOperationW rapper.run(DefaultCancellableOperationWrapper.java:55)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Alexander Gurov wrote:
> Could you please describe what kind of problems you have found?
FUDForum. Page generated in 0.03761 seconds
