Home » Eclipse Projects » Sirius » How to add Ecore types as a platform resource to a Sirius design project
How to add Ecore types as a platform resource to a Sirius design project [message #1596376] Sun, 01 February 2015 11:35 Go to next message
I have a Sirius library project, and would like to add the Ecore types to the project.
index.php/fa/20693/0/
When I right click on the editor and select the Load Resource object and specify
platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore
I'm able to load it, but then it disappears after I close and reopen the library.odesign file.
How can I ensure that it is always loaded? For example, the Obeo SysML Designer design file has the Ecore.ecore resource and many others loaded by default when loaded.
index.php/fa/20694/0/
Thanks!
Elvis Dowson
Re: How to add Ecore types as a platform resource to a Sirius design project [message #1608093 is a reply to message #1596376] Mon, 09 February 2015 04:12 Go to previous message
Hi Elvis,
If the library.odesign doesn't have references toward elements from
Ecore.ecore then this resource will not be loaded automatically. The
sysml.odesign probably has references toward this resource (directly or
indirectly).
> Thanks!
> Regards,
> Elvis Dowson
Florian - Obeo
Need professional services for Sirius?
Previous Topic:Save failed after deletion
Next Topic:Xcore dynamic instances support
Current Time: Thu Jun 12 12:51:07 EDT 2025
Powered by FUDForum. Page generated in 0.04953 seconds
