Home » Modeling » EMF » Eclipse Indigo 3.7.2 Proxy Problem(Eclipse)
Eclipse Indigo 3.7.2 Proxy Problem [message #1591361] Thu, 29 January 2015 13:35 Go to next message
Dragos Vlasceanu is currently offline Dragos VlasceanuFriend
Hello everybody
i'm new on this forum so i'm sorry if i didn't open the right topic
I have Eclipse Indigo version 3.7.2
Build ID: M20120208-0800
Our company has proxy implementation from Zscaler so we provided
proxy : proxy.zscaler.net
port: 80
i've tried to put at Windows -> Preferences -> General-> Network Connection
at Manual and set the host and port and auth, but no luck.
i tried also to modify the eclipse.ini file and put
-Dorg.eclipse.ecf.provider.filetransfer.excludeContributors=org.eclipse.ecf.provider.filetransfer.httpclient
-Dhttp.proxyPort=80
-Dhttp.proxyHost=gateway.zscaler.net
-Dhttp.proxyUser=europe\dvlasceanu
-Dhttp.proxyPassword=Ready2prepare
-Dhttp.nonProxyHosts=localhost|
-Djava.net.preferIPv4Stack=true
but no luck. It still give me the same error.
i try for example to access marketplace.eclipse.org/marketplace-client-intro..................you can see the link in the attachment but it gave me the error:
Unable to read repository at marketplace.eclipse.org/marketplace-client-intro......................
marketplace.eclipse.org/marketplace-client-intro.............. is not a valid repository location.
Can you please advice me what to do in order to work the repositories when i use proxy?
  • Attachment: Capture.JPG
    (Size: 111.90KB, Downloaded 299 times)
Re: Eclipse Indigo 3.7.2 Proxy Problem [message #1591963 is a reply to message #1591361] Thu, 29 January 2015 21:14 Go to previous messageGo to next message
This isn't an EMF question. Try the eclipse.newcomers forum.
On 29.01.2015 15:07, Dragos Vlasceanu wrote:
> Hello everybody
> port: 80
> -Dhttp.proxyPort=80
Ed Merks
Re: Eclipse Indigo 3.7.2 Proxy Problem [message #1851737 is a reply to message #1591963] Thu, 14 April 2022 09:34 Go to previous messageGo to next message
panda mkk is currently offline panda mkkFriend
Member
hi, my friend, have you solved it? I have the same problem
Re: Eclipse Indigo 3.7.2 Proxy Problem [message #1851755 is a reply to message #1851737] Fri, 15 April 2022 04:56 Go to previous message
It still is not an EMF question. Perhaps your problems similar to that one that is solved by the approach described in this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=578341#c23
Ed Merks
Previous Topic:[CDO] How can we prevent TimeoutRuntimeException for large commits
Next Topic:[CDO] Thread blocked on CDOIDUtil.createLong
Current Time: Sat Sep 21 00:08:29 GMT 2024
Powered by FUDForum. Page generated in 0.04479 seconds
