Home » Archived » BIRT » Exporting Reports from Windows to Linux Environment
Exporting Reports from Windows to Linux Environment [message #1589122] |
Wed, 28 January 2015 03:47  |
I've got 3 different BIRT Reports, created with the Birt-Report-Designer 4.4.1.
Everything works fine on my Machine with Windows 7 installed an running on an Apache Tomcat 8.0.15 and jdk 1.7.0.67.
Database is Oracle 11g.
Now I need to change the Environment and export these 3 Reports to a Linux-Server.
Linux with Apache Tomcat 8.0.15 and jdk 1.7.0.67:
- Report 1 - doesn't work, throws: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
- Report 2 - works fine
- Report 3 - exactly the same error as Report 1
Linux with Weblogic and jdk 1.7.0.67:
- Report 1 - works fine
- Report 2 - doesn't work, throws:
org.eclipse.birt.report.engine.api.EngineException: An exception occurred during processing. Please see the following message for details: Failed to prepare the query execution for the data set: test Cannot get the result set metadata. org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object. SQL error #1:ORA-12704: character set mismatch ; java.sql.SQLException: ORA-12704: character set mismatch
- Report 3 - doesn't work, throws:
Multiple exceptions occurred.
(basically ORA-12704: character set mismatch aswell)
Can someone help me with this? Maybe some Ideas on what to look at in my Reports / App Servers / Database?
I was able to trace the ORA-12704: character set mismatch in Weblogic to one Dataset (used in Report 2 and 3), which means: as soon as I added that Dataset to e.g. a table-binding I got that error.
That dataset has the following SQL query:
WITH papp AS
SELECT ? AS appsession from dual
,pstart AS
SELECT ? AS startdate from dual
,pgroup AS
SELECT ? AS groupin from dual
,pend AS
SELECT ? AS enddate from dual
,ptype AS
SELECT ? AS stype from dual
,pdt AS
SELECT ? AS datatype from dual
,pdt1 AS
SELECT ? AS datatype1 from dual
,pdt2 AS
SELECT ? AS datatype2 from dual
,pdt3 AS
SELECT ? AS datatype3 from dual
,pdt4 AS
SELECT ? AS datatype4 from dual
,pdt5 AS
SELECT ? AS datatype5 from dual
,pdt6 AS
SELECT ? AS datatype6 from dual
select
trunc(v.TIME_STAMP, pgroup.groupin) "Datum"
,case UPPER(m.display_type)
when 'AVG' then (
case md.metric_id
when 1 then dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2),nvl(pdt1.datatype1,4))
when 2 then dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2),nvl(pdt2.datatype2,4))
when 3 then dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2),nvl(pdt3.datatype3,4))
when 4 then dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2),nvl(pdt4.datatype4,4))
when 5 then dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2),nvl(pdt5.datatype5,4))
when 6 then dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2),nvl(pdt6.datatype6,4))
end
when 'MAX' then (
case md.metric_id
when 1 then dbareport.dbareport_pkg.zData(round(max(v.metric_curr_value), 2),nvl(pdt1.datatype1,4))
when 2 then dbareport.dbareport_pkg.zData(round(max(v.metric_curr_value), 2),nvl(pdt2.datatype2,4))
when 3 then dbareport.dbareport_pkg.zData(round(max(v.metric_curr_value), 2),nvl(pdt3.datatype3,4))
when 4 then dbareport.dbareport_pkg.zData(round(max(v.metric_curr_value), 2),nvl(pdt4.datatype4,4))
when 5 then dbareport.dbareport_pkg.zData(round(max(v.metric_curr_value), 2),nvl(pdt5.datatype5,4))
when 6 then dbareport.dbareport_pkg.zData(round(max(v.metric_curr_value), 2),nvl(pdt6.datatype6,4))
end
when 'MIN' then (
case md.metric_id
when 1 then dbareport.dbareport_pkg.zData(round(min(v.metric_curr_value), 2),nvl(pdt1.datatype1,4))
when 2 then dbareport.dbareport_pkg.zData(round(min(v.metric_curr_value), 2),nvl(pdt2.datatype2,4))
when 3 then dbareport.dbareport_pkg.zData(round(min(v.metric_curr_value), 2),nvl(pdt3.datatype3,4))
when 4 then dbareport.dbareport_pkg.zData(round(min(v.metric_curr_value), 2),nvl(pdt4.datatype4,4))
when 5 then dbareport.dbareport_pkg.zData(round(min(v.metric_curr_value), 2),nvl(pdt5.datatype5,4))
when 6 then dbareport.dbareport_pkg.zData(round(min(v.metric_curr_value), 2),nvl(pdt6.datatype6,4))
end
else dbareport.dbareport_pkg.zData(round(avg(v.metric_curr_value), 2), 0)
end metric_curr_value
when 'AVG' then round(avg(v.metric_value),2)
when 'MAX' then round(max(v.metric_value),2)
when 'MIN' then round(min(v.metric_value),2)
else avg(v.metric_value)
end metric_value
, md.metric_id
,case ptype.stype
when 'C' then
case md.metric_id
when 1 then dbareport.dbareport_pkg.zDatatype(nvl(pdt1.datatype1,4))
when 2 then dbareport.dbareport_pkg.zDatatype(nvl(pdt2.datatype2,4))
when 3 then dbareport.dbareport_pkg.zDatatype(nvl(pdt3.datatype3,4))
when 4 then dbareport.dbareport_pkg.zDatatype(nvl(pdt4.datatype4,4))
when 5 then dbareport.dbareport_pkg.zDatatype(nvl(pdt5.datatype5,4))
when 6 then dbareport.dbareport_pkg.zDatatype(nvl(pdt6.datatype6,4))
end
else dbareport.dbareport_pkg.zDatatype(pdt.datatype)
end datatype
, c.customer_name || ' - ' || tt.target_type_desc || ' - ' ||
t.target_name || ' - ' || m.metric_desc || ' - ' || md.metric_detail_desc description
from papp, pstart, pgroup, pend, ptype, pdt, pdt1,pdt2,pdt3,pdt4,pdt5,pdt6
, dbareport.dbac_values v
inner join dbareport.dbac_selection s
on s.customer_id = v.customer_id
and s.target_id = v.target_id
and s.metric_detail_id = v.metric_detail_id
inner join dbareport.dbac_metric_detail md
on md.metric_detail_id = s.metric_detail_id
inner join dbareport.dbac_metric m
on m.metric_id = md.metric_id
inner join dbareport.dbac_target t
on t.target_id = s.target_id
inner join dbareport.dbac_target_type tt
on t.target_type_id = tt.target_type_id
inner join dbareport.dbac_customer c
on s.customer_id = c.customer_id
where
s.SESSION_ID = papp.appsession and
v.time_stamp between to_date(pstart.startdate, 'dd.mm.yyyy hh24:mi')
and to_date(pend.enddate, 'dd.mm.yyyy hh24:mi')
group by
, m.display_type
, md.metric_id
, ptype.stype
, pdt.datatype
, pdt1.datatype1
, pdt2.datatype2
, pdt3.datatype3
, pdt4.datatype4
, pdt5.datatype5
, pdt6.datatype6
order by
, trunc(v.TIME_STAMP, pgroup.groupin)
Complete errors:
Apache Tomcat 8.0.15, Report 1 and 3:
at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1114)
at org.eclipse.birt.report.service.ReportEngineService.renderReport(ReportEngineService.java:1561)
at org.eclipse.birt.report.service.BirtViewerReportService.getPage(BirtViewerReportService.java:204)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.doExecution(AbstractGetPageActionHandler.java:237)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:104)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87)
at sun.reflect.GeneratedMethodAccessor65.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at sun.reflect.GeneratedMethodAccessor64.invoke(Unknown Source)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:644)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:725)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:537)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1085)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:658)
at org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:222)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1556)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1513)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2380)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:325)
at org.eclipse.birt.report.service.ReportEngineService.renderReport(ReportEngineService.java:1555)
... 54 more
Caused by: java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.birt.chart.device.svg.SVGRendererImpl
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:190)
at org.eclipse.birt.core.framework.jar.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:46)
at org.eclipse.birt.core.framework.eclipse.EclipseConfigurationElement.createExecutableExtension(EclipseConfigurationElement.java:35)
at org.eclipse.birt.chart.util.PluginSettings.getPluginXmlObject(PluginSettings.java:1252)
at org.eclipse.birt.chart.util.PluginSettings.getDevice(PluginSettings.java:632)
at org.eclipse.birt.chart.api.ChartEngine.getRenderer(ChartEngine.java:119)
at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationBase.prepareDeviceRenderer(ChartReportItemPresentationBase.java:1222)
at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationBase.generateRenderObject(ChartReportItemPresentationBase.java:971)
at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationBase.onRowSets(ChartReportItemPresentationBase.java:904)
at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationProxy.onRowSets(ChartReportItemPresentationProxy.java:108)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.processExtendedContent(LocalizedContentVisitor.java:1074)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localizeForeign(LocalizedContentVisitor.java:591)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localize(LocalizedContentVisitor.java:176)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:37)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLRepeatHeaderLM.layoutChildren(HTMLRepeatHeaderLM.java:46)
at org.eclipse.birt.report.engine.layout.html.HTMLListLM.layoutChildren(HTMLListLM.java:72)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:717)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:321)
Weblogic - Report 2:
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1245)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1224)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.ListItemExecutor.execute(ListItemExecutor.java:66)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:249)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:269)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:86)
at org.eclipse.birt.report.service.ReportEngineService.runReport(ReportEngineService.java:1325)
at org.eclipse.birt.report.service.BirtViewerReportService.runReport(BirtViewerReportService.java:158)
at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:81)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageActionHandler.__checkDocumentExists(BirtGetPageActionHandler.java:58)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.prepareParameters(AbstractGetPageActionHandler.java:118)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:103)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.GeneratedMethodAccessor155.invoke(Unknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:751)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:844)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:280)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:254)
at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:136)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:341)
at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:25)
at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3367)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3333)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
at weblogic.servlet.provider.WlsSubjectHandle.run(WlsSubjectHandle.java:57)
at weblogic.servlet.internal.WebAppServletContext.doSecuredExecute(WebAppServletContext.java:2220)
at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2146)
at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2124)
at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1564)
at weblogic.servlet.provider.ContainerSupportProviderImpl$WlsRequestExecutor.run(ContainerSupportProviderImpl.java:254)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:295)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:254)
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: An exception occurred during processing. Please see the following message for details:
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:657)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:152)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteQuery(DataGenerationEngine.java:83)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:275)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1947)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
... 65 more
Caused by: org.eclipse.birt.data.engine.core.DataException: Failed to prepare the query execution for the data set: test
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:350)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:463)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:178)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:637)
... 70 more
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot get the result set metadata.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:52)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:84)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:414)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getProjectedColumns(PreparedStatement.java:377)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.declareCustomColumn(PreparedStatement.java:1223)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.addCustomFields(DataSourceQuery.java:684)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.prepareColumns(DataSourceQuery.java:407)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.prepare(DataSourceQuery.java:345)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:517)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:346)
... 75 more
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:481)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaUsingPolicy1(Statement.java:420)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaData(Statement.java:316)
at org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.getMetaData(BidiStatement.java:56)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doGetMetaData(OdaQuery.java:423)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.getMetaData(OdaQuery.java:390)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:407)
... 82 more
Caused by: java.sql.SQLException: ORA-12704: character set mismatch
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:445)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:396)
at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:879)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:450)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:192)
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:531)
at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:207)
at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:884)
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1167)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1289)
at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3594)
at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3638)
at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1495)
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:477)
... 88 more
Current Time: Mon Jun 23 15:51:12 EDT 2025
Powered by FUDForum. Page generated in 0.05405 seconds
