Home » Eclipse Projects » BPMN 2.0 Modeler » how to create an image on a server
how to create an image on a server [message #1585909] Mon, 26 January 2015 15:04 Go to next message
Flavio Donze is currently offline Flavio DonzeFriend
Hello
I would like to create an image of a BPMN diagram on the server side without having to load the entire editor environment.
I got the following test snipped so far:
		URI modelUri = URI.createFileURI("D:/temp/data.bpmn");
		URI diagramUri = URI.createFileURI("D:/temp/data.diagram");
		TransactionalEditingDomain editingDomain = createResourceSetAndEditingDomain();
		ResourceSet resourceSet = editingDomain.getResourceSet();
		resourceSet.setURIConverter(new ProxyURIConverterImplExtension(modelUri));
		Bpmn2ResourceImpl resource = (Bpmn2ResourceImpl) resourceSet.createResource(modelUri,
				Bpmn2ModelerResourceImpl.BPMN2_CONTENT_TYPE_ID);
		ModelHandler modelHandler = ModelHandlerLocator.createModelHandler(modelUri, resource);
		URI uridiagram = diagramUri.appendFragment("/0"); // diagram is first object
		Diagram diagram = (Diagram) editingDomain.getResourceSet().getEObject(uridiagram, true);
The question now is how do I generate the according GraphicalEditPart from the diagram? If I look at the EditPartFactories e.g. org.eclipse.graphiti.ui.internal.partfactory.PictogramsEditPartFactory it would require to initialize a whole editor. Does anybody have a snippet or can point me in the right direction?
greets and thanks
Flavio
Prozessmanagement und Qualit├Ątsmanagement Software QMS/IMS
https://www.scodi.ch
Re: how to create an image on a server [message #1586049 is a reply to message #1585909] Mon, 26 January 2015 16:38 Go to previous message
Robert Brodt is currently offline Robert BrodtFriend
Hi Flavio,
Unfortunately, the diagram rendering requires MOST of the BPMN2 Modeler code. You may want to talk to Darrel on this thread - I think he's working on refactoring the code so that fewer external dependencies are required for a basic graphical viewer.
Bob
Previous Topic:Morph Gateway not available
Next Topic:Documentation for adding new Runtime
Current Time: Wed Dec 01 09:09:29 GMT 2021
Powered by FUDForum. Page generated in 0.02197 seconds
