Home » Modeling » Graphiti » Graph Editor(Best Technology to use Graph Editor)
Graph Editor [message #1580190] Fri, 23 January 2015 10:41 Go to next message
Kalpana Ramasamy is currently offline Kalpana RamasamyFriend
Requirement is
Only one type of element(Node) exists in the Editor
Editor has to show nodes and connections between nodes
I dont want to start from ecore to create diagram file
Already generated model is present
Is the Graphiti the best technology to use?
Re: Graph Editor [message #1585507 is a reply to message #1580190] Mon, 26 January 2015 09:55 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Kalpana,
Graphiti should be well suited for your usecase. Have you seen and tried the
"Plug-in with a Graphiti Editor" wizard? It is part of the create "New
Plug-in Project" wizard and will allow to add all classes needed for a
simple diagram editor based on EClasses in you ecore models installed in
your IDE. Simply start the new plug-in project wizard, click next until you
reach the templates page and select the Graphiti editor template.
Michael
Re: Graph Editor [message #1694045 is a reply to message #1585507] Thu, 30 April 2015 08:56 Go to previous message
Thank You Michael,
I have started playing around with Graphiti Editor
Previous Topic:SWT Font management in Graphiti
Next Topic:Adding shapes to the Diagram on the open of the Editor
Current Time: Mon Apr 06 00:16:30 GMT 2020
Powered by FUDForum. Page generated in 0.01421 seconds
