Home » Eclipse Projects » Sirius » Create a sirius diagram programmatically(Create a sirius diagram programmatically)
Create a sirius diagram programmatically [message #1578515] Thu, 22 January 2015 07:50 Go to next message
I'm trying to create a modeling environment and I want to use Sirius as graphical editor. I have a CTabFolder and in each item(CTabItem) I want a different kind of visualization. I have been searching and found https://www.eclipse.org/forums/index.php/t/633830/ so I think that DialectUIManager is the class that creates the diagram representation, but I still don't know how add this diagram representation to a parent Composite. Is there any way to do this?
Thanks for any help.
Anthony
Re: Create a sirius diagram programmatically [message #1580472 is a reply to message #1578515] Fri, 23 January 2015 09:12 Go to previous messageGo to next message
I think that you should take a look in the code of
DiagramDialectUIServices.openEditor to see how is created a DDiagramEditor.
Out of curiosity, you want to display several representations in a
containing CTabFolder, what is represented by this containing
CTabFolder? A Sirius session?
Steve
Le 22/01/2015 13:50, Anthony Garmendia a écrit :
> Cheers,
> Anthony
Steve Monnier - Obeo
Need professional services for Sirius?
Re: Create a sirius diagram programmatically [message #1585945 is a reply to message #1580472] Mon, 26 January 2015 10:29 Go to previous message
Hello Steve,
First of all, thanks for the reply. I would like to open a Sirius editor in a CTabItem, add the diagram representation in a parent Composite. I understand that I have to create s Sirius session and create the editor.
For that I follow the steps from Alex Lagarde in
The thing is that I cannot find a method in which I can create the editor inside CTabItem. I would expect a method that has as a parameter, for example: (Composite parent) or maybe I have to do it in other way.
I searched the class, but I'm not sure what would I have to do?
Thanks.
Antonio
Previous Topic:Immediate execution Tool
Next Topic:Different properties view?
Current Time: Sat Jun 21 01:52:00 EDT 2025
Powered by FUDForum. Page generated in 0.25265 seconds
