Re: FXSceneHolder doesn't open Main scene. Not on FX application thread; currentThread = main [message #1576406 is a reply to message #1575255] |
Wed, 21 January 2015 09:43   |
[reglament.editor.eclipse.core.views.ReglamentViewPart]
import org.eclipse.fx.ui.workbench3.FXViewPart;
public class ReglamentViewPart extends FXViewPart {
public void openReglament(String reglamentName, String projectPath){
FXSceneHolder.getInstance().getReglamentEditor().openReglament(reglamentName, projectPath);
If you mean "javafx.embed.swt", FXViewPart (org.eclipse.fx.ui.workbench3.FXViewPart) already imported it.
Re: FXSceneHolder doesn't open Main scene. Not on FX application thread; currentThread = main [message #1576445 is a reply to message #1576406] |
Wed, 21 January 2015 10:11   |
Could you try starting with -Defxclipse.osgi.hook.debug=true. This
should give you some debug information on the OSGi-Hook.
One thing that could be on Linux is that you are launching with SWT-Gtk3
which is not supported by JavaFX and so we refuse to load the
swt-embedding code but this should have led to another exception which I
can't find in your stacktrace
Anyways turn on this option and provide us the output which start with
FXModuleClassloader...... or FXClassLoader......
The rest of the output is not important.
Tom
> projectPath);
Re: FXSceneHolder doesn't open Main scene. Not on FX application thread; currentThread = main [message #1576550 is a reply to message #1576542] |
Wed, 21 January 2015 11:29   |
Ok yeah my guess was right - see
> FXClassLoader#createJREBundledClassloader - Started
> FXClassLoader#createJREBundledClassloader - Assumed location (Java 8/Java 7): /opt/jdk1.8.0_25/jre/lib/ext/jfxrt.jar
> FXClassLoader#createJREBundledClassloader - SWT is available use different loading strategy
> FXClassLoader#createJREBundledClassloader - Searching for SWT-FX integration at /opt/jdk1.8.0_25/jre/lib/jfxswt.jar
> FXClassLoader#createJREBundledClassloader - Found SWT/FX
> FXClassLoader#createJREBundledClassloader - Delegate to system classloader
> FXClassLoader.SWTFXClassloader#init - Primary Loader sun.misc.Launcher$ExtClassLoader@3ac8cf9b
> FXClassLoader.SWTFXClassloader#init - Lastresort Loader org.eclipse.osgi.internal.loader.EquinoxClassLoader@761956ac[org.eclipse.swt:3.103.1.v20140903-1938(id=1939)]
> FXClassLoader#createJREBundledClassloader - Ended
> FXModuleClassloader#findLocalClass trying to load class 'javafx.embed.swt.FXCanvas'
> FXModuleClassloader#findLocalClass - Someone is trying to load FXCanvas. Need to check for GTK3
> FXModuleClassloader#findLocalClass trying to load class 'org.eclipse.swt.SWT'
> FXClassLoader.SWTFXClassloader#findClass - Loading org.eclipse.swt.SWT with primary
> FXClassLoader.SWTFXClassloader#findClass - ClassNotFoundException thrown
> FXClassLoader.SWTFXClassloader#findClass - Loading org.eclipse.swt.SWT with last resort
> FXClassLoader.SWTFXClassloader#findClass - Result org.eclipse.swt.SWT class org.eclipse.swt.SWT
> FXModuleClassloader#findLocalClass - We are on GTK need to take a closer look
> FXModuleClassloader#findLocalClass trying to load class 'org.eclipse.swt.internal.gtk.OS'
> FXClassLoader.SWTFXClassloader#findClass - Loading org.eclipse.swt.internal.gtk.OS with primary
> FXClassLoader.SWTFXClassloader#findClass - Loading org.eclipse.swt.internal.gtk.OS with last resort
> FXClassLoader.SWTFXClassloader#findClass - Result org.eclipse.swt.internal.gtk.OS class org.eclipse.swt.internal.gtk.OS
> FXModuleClassloader#findLocalClass - We are on GTK3 - too bad need to disable JavaFX for now else we'll crash the JVM
So you need to force SWT to use Gtk2! e.g. by setting SWT_GTK3=0 in the
launcher environment, not sure the --launcher.GTK_version works when
starting a inner instance.
Tom
On 21.01.15 12:22, Alex Franz wrote:
> Here is stack trace with enabled debug option.
FUDForum. Page generated in 0.05675 seconds
