Re: Different properties view? [message #1576788 is a reply to message #1573350] |
Wed, 21 January 2015 14:21 |
Unfortunately, using Sirius to represent Odesign model is not well
supported because Sirius manage odesign models differently than other
models for various reasons like performances.
However, if you want to produce a new user interface (or only new
properties view) to edit odesign models you can take a look to the EEF
framework (https://eclipse.org/eef/).
Steve
Le 19/01/2015 18:46, Max Bureck a écrit :
> By the way: It looks like changes made through the editor on the Odesign
> model are not saved when saving in the graphical editor. Do Odesign
> models have to be treated specially when serializing them or so? I did
> not encounter this behavior when working with own meta models.
Steve Monnier - Obeo
Need professional services for Sirius?
Steve Monnier - Obeo Canada
Re: Different properties view? [message #1577192 is a reply to message #1576788] |
Wed, 21 January 2015 19:17 |
Max Bureck Messages: 19 Registered: April 2013 |
Hey Steve,
The properties view in the "Viewpoint Specification Editor" is actually pretty damn good, so I don't see the need to create an own one (at least for this, or other tree based editors).
I actually got very far in creating the designer for Odesign, It can already display and edit a lot, but the most severe thing is that it cannot really save.
Somehow I feel (without knowing the insides of the implementation of the Odesign meta model and surrounding technologies) that serializing a valid instance of that meta model should not be a difficult thing. I even can open an Odesign model with the "Sample Reflective Ecore Model Editor", make changes and save it again.
I can imagine that the "Viewpoint Specification Editor" and it's properties view have a lot of magic inside and it would be hard to re-use parts of it. So I could consider learning how to use EEF to create a properties view for my graphical editor. But as long as the graphical editor is not able to save, this is kind of pointless. The properties view for the "Viewpoint Specification Editor" is awesome (you fellas did a really great job!), so it does not need a replacement.
Max
Re: Different properties view? [message #1587341 is a reply to message #1585820] |
Tue, 27 January 2015 09:30 |
We have some JUnit test where the ODesign is modified for the purpose of
the test, but in the common usage of Sirius it should not be modified
and needing saving. Especially, if the odesign is in the plugins.
You can try to override it but you can experience drawbacks in
performances and unstability.
Steve
Le 26/01/2015 14:58, Max Bureck a écrit :
> I debugged the Sirius code to determine why changes to .odesign files
> are not saved. In method
> org.eclipse.sirius.business.internal.session.danalysis.ResourceSaveDiagnose#isSaveable()
> There is an explicit check if a file to be saved is an Odesign model. If
> this is the case, the method returns false.
> I was not able to get in this state, without explicitly adding an
> Odesign model to an .aird file via the UI and then modify this. Are
> there situations where an Odesign model would actually be saved
> accidentally, if this check would be omitted?
> Thanks and best regards,
> Max
FUDForum. Page generated in 0.03751 seconds
