Re: Dstore won't authenticate, SSH does [message #29306 is a reply to message #29152] |
Tue, 04 November 2008 19:45 |
David McKnight Messages: 244 Registered: July 2009 |
Hi Rennie,
I'm not sure what the problem may be but there are a couple possibilities
that have come up before. Have you tried viewing the console from which the
daemon runs to see if there's any useful information? Unfortunately, dstore
doesn't log daemon authentification problems.
Here are a couple bugs that had been opened regarding problems connecting to
the daemon:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=252657
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245714
Could you let me know a bit more about your configuration? (i.e. which port
the daemon runs on, which port is specified in the server launcher
properties, etc.).
Dave
"Rennie allen" <rallen@goahead.com> wrote in message
news:97322c3a1c9c1a8ded8c1bad2361e0d7$1@www.eclipse.org...
> If I set the properties of any of the services to use dstore, they will
> not authenticate; OTOH if I set the properties of the services to use SSH
> then (using the identical password) the services work fine.
> I can't seem to find any log that is produced by the dstore daemon on the
> target.
> The error I receive is: RSEC1002
> The target is Puppy Linux 4.1, and the dstore daemon is running with Java
> 1.5.0_09.
> How do I go about determining why the authentication is failing?
> Rennie
Re: Dstore won't authenticate, SSH does [message #577840 is a reply to message #29152] |
Hi Rennie,
the daemon:
properties, etc.).
Dave
> target.
> 1.5.0_09.
> Rennie
FUDForum. Page generated in 0.03079 seconds
