eclipse text editor support for SJIS encoding [message #290327] |
Tue, 23 August 2005 21:37 |
Originally posted by: pmac.nospam.tensilica.nospam.com
Support for sjis encoding doesn't seem to be there by default - how do i
enable it for eclipse text editors (actually the CDT C editor) ?
THANKS
PMac
Re: eclipse text editor support for SJIS encoding [message #290328 is a reply to message #290327] |
Tue, 23 August 2005 21:44 |
Guess I should have said that's for eclipse 3.0.2 (windows + linux gtk)
> THANKS
> PMac
Re: eclipse text editor support for SJIS encoding [message #290329 is a reply to message #290328] |
Tue, 23 August 2005 22:15 |
Originally posted by: bob.objfac.com
Last time I looked "SJIS" was the Java name for the "SHIFT_JIS"
encoding. It's probably a function of your platform, e.g., do you have
Japanese character support?
If you do, have you tried to set the text encoding in preferences?
Bob
>>THANKS
>>PMac
Re: eclipse text editor support for SJIS encoding [message #290330 is a reply to message #290329] |
Tue, 23 August 2005 23:30 |
My test machine has a Japanese version of windows which supports SJIS
(Shift_JIS). Actually my own "US" windows machine also offers Shift_JIS
encoding as a rendering option in IE.
However on neither machine do I see it offered as an encoding in
workbench -> preferences -> editors -> encodings or from the Edit ->
encodings menu. Those 2 encoding choices get their lists from different
places ... i saw a post from Nick Edgar on this group that the prefs choice
comes from a fixed list in a messages.properties file under
"org.eclipse.ui.internal.ide". As a hack I tried adding to that list ... it
did extend the encodings offered under preferences, but it didn't let me
select them.
"Bing" ... light goes on ... do the Java distributions differ in what
encodings they support? I just looked at my java installation and it does
not include charsets.jar. (See
http://java.sun.com/j2se/1.4.2/docs/guide/intl/encoding.doc. html).
Dropping charsets.jar into my JRE, however, does not seem to extend the
preferences encodings menu. Is that fixed by the properties file? Is that
really fixed by the properties file? I just unpacked the "nl1.jar" from the
translation pack and that also has the same 6 entries for the encodings.
Maybe I'm being a bit optimistic, but if i
- put in a JRE with the extended charsets
- rebuild the "ide.jar" with a messages.properties with Shift_JIS as a
choice
will the text editor use that encoding successfully?
THANKS
PMac
"Bob Foster" <bob@objfac.com> wrote in message
news:deg76u$gsb$1@news.eclipse.org...
> Last time I looked "SJIS" was the Java name for the "SHIFT_JIS" encoding.
> It's probably a function of your platform, e.g., do you have Japanese
> character support?
> Bob
>>>THANKS
>>>PMac
Re: eclipse text editor support for SJIS encoding [message #290350 is a reply to message #290330] |
Wed, 24 August 2005 12:37 |
>select them.
>choice
No. There are two things to know here:
1) the supported encodings depend on the VM you're using
2) the encodings shown in Eclipse are provided through the
org.eclipse.ui.encodings extension point. This list is quite short and
contains the common ones. If you install the Japanese fragment I'd
expect the encoding to appear in the list (did not try it). If the
encoding is not in that list it's not a problem: as long as it is
supported by your VM you should be able to manually enter the encoding
(just tried SJIS and it worked) and from then on it will also appear in
the list.
HTH
Dani
>THANKS
>PMac
>>character support?
>>Bob
>>>>THANKS
>>>>PMac
Re: eclipse text editor support for SJIS encoding [message #290366 is a reply to message #290351] |
Wed, 24 August 2005 15:25 |
Tom Eicher wrote:
> Note that the list in the combo may not be complete - try to type in the
> name of the encoding you want, it may just work.
Why isn't it complete? You can get a list of supported encodings from
Charset.availableCharsets().
Time for a bug report?
Bob
Re: eclipse text editor support for SJIS encoding [message #290373 is a reply to message #290366] |
Wed, 24 August 2005 16:46 |
Bob Foster wrote:
>> the name of the encoding you want, it may just work.
We discussed this and decided not to do so because the list is quite
long and because people often know the alias and not the canonical name.
Dani
> Bob
Re: eclipse text editor support for SJIS encoding [message #290380 is a reply to message #290373] |
Wed, 24 August 2005 18:12 |
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:dei88v$2u8$1@news.eclipse.org...
> We discussed this and decided not to do so because the list is quite long
Now I know what I can get away with, it seems reasonable ... but I couldn't
guess. There is some prompting (& help) missing and a difference between the
2 places you can set encodings that threw me.
edit -> encoding offers a fixed list and a separate "others..." which lets
you type in a dialog
prefs -> wb -> editors just has the combo
I have used and programmed combos enough to hate them (swt cross platform is
one example of why not to like them) that i didn't even think of trying to
overtype with a value not in the list.
But now I understand it seems reasonable .....
THANKS MUCHO
PMac
> Dani
>> Bob
Re: eclipse text editor support for SJIS encoding [message #290406 is a reply to message #290380] |
Thu, 25 August 2005 08:07 |
Ah, I see what you mean. My comments are R3.1 based. In R3.1 we now use
the same list everywhere.
Dani
>THANKS MUCHO
>PMac
>>Dani
>>>Bob
FUDForum. Page generated in 0.02554 seconds
