How do I change JRE javaw path in Eclipse 3.0? [message #287693] |
Wed, 06 July 2005 15:39 |
Originally posted by: falcom.globaltrak.com.my
To eclipse users:
How do i change JRE javaw.exe path in Eclipse 3.0?
Eclipse auto configure the JRE javaw.exe path, which I would like to
change.
Regards & thanks,
Chin Hoong
Re: How do I change JRE javaw path in Eclipse 3.0? [message #287700 is a reply to message #287693] |
Wed, 06 July 2005 16:13 |
Are you saying you want to java.exe instead of javaw.exe or are you
saying you want to use a different JRE entirely from the default?
If you are saying you want to switch to use java.exe, then on the Java
Application Launch Configuration of interest, switch to the "JRE" page,
select "Alternate JRE", select the JRE of interest, and then in the
group just below that select "Alternate" radio button and put in java
instead.
If you are saying you want to switch to a different JRE entirely, then
go to Windows->Preferences->Java->Installed JRE's, and use the "ADD"
button to add a new jre. You can then make it the default for the
workspace there.
ChinHoong wrote:
> To eclipse users:
> change.
> Regards & thanks,
> Chin Hoong
Rich Kulp
Re: How do I change JRE javaw path in Eclipse 3.0? [message #287797 is a reply to message #287700] |
Thu, 07 July 2005 03:46 |
Hi Rich,
I am using Eclipse 3.0 and Windows XP.
Click on Eclipse Help/ About Eclipse platform/ Configuration Details/
I can see my Java VM path is "eclipse.vm=C:\WINDOWS\system32\javaw.exe"
How can I change this path to other directory?
Thanks!
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:dagvv5$sda$1@news.eclipse.org...
> Are you saying you want to java.exe instead of javaw.exe or are you saying
> select "Alternate JRE", select the JRE of interest, and then in the group
> just below that select "Alternate" radio button and put in java instead.
> If you are saying you want to switch to a different JRE entirely, then go
> to Windows->Preferences->Java->Installed JRE's, and use the "ADD" button
> to add a new jre. You can then make it the default for the workspace
> there.
> ChinHoong wrote:
>> To eclipse users:
>> change.
>> Regards & thanks,
>> Chin Hoong
> Rich Kulp
Re: How do I change JRE javaw path in Eclipse 3.0? [message #287913 is a reply to message #287847] |
Fri, 08 July 2005 04:12 |
Hi Eric:
For the command line eclipse.exe -vm c:\....
1) You need to type in the command line-vm everytime you start up eclipse,
is there a permanet way?
2) Eclipse 3.0 is in GUI. Is there any GUI way, instead of command line?
"Eric Rizzo" <eclipse3@rizzoweb.com> wrote in message
news:dajedm$koq$1@news.eclipse.org...
> ECOS learner wrote:
>> Hi Rich,
> You can specify a JVM to use on the command-line to eclipse.exe. See
> http://eclipsewiki.editme.com/StartupProblems for details on how to do it.
> HTH,
> Eric
FUDForum. Page generated in 0.04400 seconds
