Can't select target during edge creation [message #1554579] |
Fri, 09 January 2015 09:20 |
Hello everyone,
I'm still a beginner and I've got a very annoying problem during edge creation.
I've got a Node called PortNode (which is associated to EObject Port), and I've got an edge called ConnectionEdge (which is associated to EObject Connection).
This is my model situation:
Port has 0...* Connection
Connection has 2 Port
Each port stay in a different resource, and there is another resource contains all connections.
I've tryed to create an EdgeCreation. Edge Mappings is ConnectionEdge, which has PortNode as Source Mapping and Target Mapping.
Now I'm going to use that operation, I can select a PortNode as source, but when I try to select PortNode as destination, it is blocked.
Any suggestions?
Very thank you.
Re: Can't select target during edge creation [message #1554699 is a reply to message #1554579] |
Fri, 09 January 2015 10:51 |
Esteban Dugueperoux Messages: 472 Registered: July 2009 |
Hi Tommaso,
What do you mean by it is blocked?
Nothing is created or you are in deadlock?
Best Regards.
Le 09/01/2015 10:20, Tommaso De Sica a écrit :
> Hello everyone,
> creation.
> Any suggestions?
> Very thank you.
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
FUDForum. Page generated in 0.02015 seconds
