Re: Changing icon in stereotype according to several attributes [message #1554547 is a reply to message #1553188] |
Fri, 09 January 2015 08:57 |
Thanks for your quick answers.
As Patrick suggest it would be nice contributing. I'll try to contribute
to that issue, adding basic support for logic operations should no be
very complex. Just having NOT and AND operators support would be
probably enough.
Víctor
El 08/01/2015 a las 15:58, Camille Letavernier escribió:
> Quote:
>> To support several attributes, you can contribute if you want Wink,
>> because I think that this fucntionality is not planned for the next
>> version.
> We are currently discussing the possibility to manage the Element Icon
> via a graphical property, compatible with the CSS Framework, for Papyrus
> 1.1. If it is possible to define the Element Icon from a graphical
> property, then the CSS component would allow you to select an icon based
> on a more complex expression (e.g. several stereotype attributes)
> But it is not actually "planed". It may be implemented for Mars, but I
> won't guarantee that
> Camille
FUDForum. Page generated in 0.02589 seconds
