Re: Rich Text Editor for SysML Comments [message #1547645] |
Mon, 05 January 2015 15:02 |
Hi, Wayne,
Questions about Papyrus should be directed to the Papyrus newsgroup
(included in this reply).
I don't know anything about the rich text component except that (I
think) it's only implemented on Windows platform. Somebody in the
Papyrus group may be able to answer your question, but they will
probably at least need to know which versions of Eclipse, Papyrus, and
the SysML and Rich Text features you are running.
Christian
On 2015-01-05 12:24:48 +0000, Wayne Carl said:
> I have installed the Rich Text editor in Papyrus. All of it's
> functions appear to work properly in the edit window and in the
> properties window (comment, problem, and rationale). But when I exit
> my edits are lost. Additionally, when I first place a comment on a
> diagram I can insert text directly into the graphic; however, once
> Ileave the comment I can find no way to edit the text. What am I
> missing? Is there any instruction available for the RTF feature?
> In His service,
> Wayne
Re: Rich Text Editor for SysML Comments [message #1551097 is a reply to message #1551017] |
Wed, 07 January 2015 12:03 |
Camille Letavernier Messages: 952 Registered: February 2011 |
Hi Tomas,
Nothing comes "by default" with SR1a; but if you installed Papyrus Extra Components, then the Rich Text editor is included when you update.
So:
- If you have a standard text editor, the Rich Text editor is not installed
- If you have a text editor with formatting options (Italic, Bold, ...), then the Rich Text editor is installed
It is usually not recommended to install all Papyrus Extra Components at the same time, since most of them are experimental, and you rarely need everything.
Camille
Camille Letavernier
Re: Rich Text Editor for SysML Comments [message #1574333 is a reply to message #1559936] |
Tue, 20 January 2015 06:50 |
Tomas Sandkvist Messages: 149 Registered: October 2013 |
Hi Camille!
Some additional questions. I do have Papyrus EPF RichText (Incubation) 1.0.1.v201412191003 installed, is that the RichText component you talk about?
I only get bold and italic text. Lists does not work, neither tables. If I choose qoute I get italic text in the edit window but some really weird font in the comment in the diagram.
Is there some other components I should check for?
Tomas
[Updated on: Tue, 20 January 2015 06:53] Report message to a moderator
FUDForum. Page generated in 0.03813 seconds
