Home » Eclipse Projects » EGit / JGit » "Replace with Index" and "Replace with HEAD" in Staging view do nothing
"Replace with Index" and "Replace with HEAD" in Staging view do nothing [message #1547247] Mon, 05 January 2015 10:10 Go to next message
Juan Cadavid is currently offline Juan CadavidFriend
Member
I love EGit and particularly the Staging view but ever since I started using it months ago there has been one feature I haven't been able to make work.
When I'm rebasing and I get conflicts, they are properly shown in the Staging view under Unstaged Changes. When I decide that I won't merge anything but will keep the incoming commit's changes, and click "Replace with Index", nothing happens, and nothing is logged on Error view. If I decide to keep my local version of the file, "Replace with HEAD Revision" won't do anything nor log anything either.
The files belong to projects which are in the workspace and are open.
I work with a fairly large repository [0], if size could matter for this. Any clues?
Thanks !
Juan
[0] https://git.eclipse.org/c/papyrus/org.eclipse.papyrus.git/
Re: "Replace with Index" and "Replace with HEAD" in Staging view do nothing [message #1549004 is a reply to message #1547247] Tue, 06 January 2015 09:05 Go to previous messageGo to next message
Member
I'm on Windows by the way.
Re: "Replace with Index" and "Replace with HEAD" in Staging view do nothing [message #1565679 is a reply to message #1549004] Thu, 15 January 2015 12:15 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
Install at least 3.6.0 and use "Replace with theirs" or "Replace with ours" depending which side you want, then move this entry to the "Staged Changes" pane.
Re: "Replace with Index" and "Replace with HEAD" in Staging view do nothing [message #1565730 is a reply to message #1565679] Thu, 15 January 2015 12:55 Go to previous message
Member
Just saw those new actions, and it works well. Thank you!
Previous Topic:insert git head into code
Next Topic:I'm having problems with CommitTimeRevFilter
Current Time: Fri Jun 05 20:20:49 GMT 2020
Powered by FUDForum. Page generated in 0.01846 seconds
