Re: MARTE profile example [message #1546864 is a reply to message #1541947] |
Mon, 05 January 2015 05:15 |
Abhijit Deshpande Messages: 11 Registered: December 2014 |
If I check eclipse installation details (Help -> Installation Details), I do see that following MARTE related components are successfully installed:
1. Papyrus Marte (Incubation)
2. Papyrus Marte properties (Incubation)
3. Papyrus Marte Textedit (Incubation)
But, still when I try to create a new Papyrus project; I do not see MARTE profile listed over there. Am I missing something here?
BTW, just to confirm that I am following proper method for Papyrus extra installations, I also tried to install another profile "RobotML". And, I can see under "Installation Details" that "Papyrus RobotML Modeling Tools" is successfully installed. And, when I try to create a new Papyrus project; I can see that "RobotML" profile is listed there.
So, I am not able to figure out why am I not able to see "Marte" profile while creating Papyrus project; where-as I can successfully see "RobotML" profile. And, I have followed similar methods to install both these profiles.
Any help on debugging this issue is appreciated.
Abhijit Deshpande
Re: MARTE profile example [message #1735865 is a reply to message #1541947] |
Thu, 23 June 2016 11:09 |
Raoudha Saida Messages: 41 Registered: June 2016 |
Member |
I can't apply Marte profile too.
I followed these steps:
1) New>papyrus project
I give the name of the project, next I choose Profile.
2) New > papyrus model
I enter MARTE sources manually, using this link:
http://git.eclipse.org/c/papyrus/org.eclipse.papyrus.git/tree/extraplugins/marte/org.eclipse.papyrus.marte.static.profile/resources?id=8c0a29c3e4b19676126faf9e13e7029bf02d1a06&h=master
For step 1) , I used MARTE.profile.di, MARTE.profile.notation, MARTE.profile.uml.
For ste 2) I used MARTE_Library.library.di, MARTE_Library.library.notation, MARTE_Library.library.uml.
For the test of this profile,
New> papurys project.
When I apply the profile from properties, I had the attached error .
I'm using eclipse Luna , java se development kit 8 update 92
Please can you help me? Thanks in advance
FUDForum. Page generated in 0.02734 seconds
