Koneki OMA DM Simulator Source code [message #1540303] |
Thu, 01 January 2015 12:05 |
Kailash Kumar Messages: 3 Registered: November 2014 |
Hi everyone!!
I've downloaded the source code for Koneki OMA DM Simulator from the git source provided by eclipse and it is working fine as an eclipse plugin with Funambol DM Server 3.6.
But instead of using it as eclipse plugin, I want to test it with Funambol server by building the simulator source code and then running it.
So I am able to build the source code successfully and it is running some test cases successfully too. But how can I get the simulator wizard from here similar to the case when we use it as a plugin?
And what are the results of these test cases?
Also is there any way we can use this simulator code as a DM client?
FUDForum. Page generated in 0.04070 seconds
