Home » Eclipse Projects » Eclipse Platform » Troubles with eclipse.buildScript and versions of dependent plugins
Troubles with eclipse.buildScript and versions of dependent plugins [message #281348] Fri, 18 February 2005 23:27 Go to next message
Larry is currently offline LarryFriend
In 3.1.0_200409240800, I'm using this:
<project name="ant" default="buildOne" basedir=".">
<property name="bootclasspath" value=""/>
<property name="basews" value="${ws}"/>
<property name="baseos" value="${os}"/>
<property name="basearch" value="${arch}"/>
<property name="basenl" value="${nl}"/>
<property name="javacFailOnError" value="true"/>
<property name="javacDebugInfo" value="on"/>
<property name="javacVerbose" value="true"/>
<property name="javacSource" value="1.4"/>
<property name="javacTarget" value="1.4"/>
<property name="compilerArg" value=""/>
<!-- advance this manually, with the manifest version -->
<target name="buildOne">
<eclipse.buildScript buildDirectory="c:/workspace/RUNTIME"
elements="plugin@RUNTIME" buildingOSGI="true"/>
</target>
</project>
to generate a build script from this:
<plugin
name = "%pluginName"
id = "runtime"
version = "1.0.0"
provider-name = "%providerName">
<requires>
<import plugin="org.eclipse.core.runtime"/>
<import plugin="org.eclipse.emf.codegen.ecore"/>
<import plugin="org.eclipse.emf.ecore"/>
<import plugin="org.eclipse.emf.ecore.edit"/>
<import plugin="org.eclipse.emf.ecore.xmi"/>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.ui.ide"/>
<import plugin="org.eclipse.xsd"/>
<import plugin="org.eclipse.core.resources"/>
</requires>
<runtime>
<library name="runtime/runtime.jar">
<export name="*"/>
</library>
<library name="commons-jxpath-1.1.jar">
</library>
</runtime>
<extension point="org.eclipse.emf.ecore.generated_package">
<package
uri = "http://www..com//2005/runtime"
class = "runtime.RuntimePackage" />
</extension>
<package
uri = "http:////runtime/adapter.ecore"
class = "runtime.adapter.AdapterPackage" />
</extension>
</plugin>
and I get this:
!ENTRY org.eclipse.pde.build 2 1 Feb 18, 2005 15:14:08.456
!MESSAGE Some inter-plug-in dependencies have not been satisfied.
!SUBENTRY 1 RUNTIME 2 2 Feb 18, 2005 15:14:08.456
!MESSAGE Missing required plug-in org.eclipse.core.runtime_0.0.0.
!MESSAGE Missing required plug-in org.eclipse.emf.codegen.ecore_0.0.0.
!MESSAGE Missing required plug-in org.eclipse.emf.ecore_0.0.0.
!MESSAGE Missing required plug-in org.eclipse.emf.ecore.edit_0.0.0.
!MESSAGE Missing required plug-in org.eclipse.emf.ecore.xmi_0.0.0.
!MESSAGE Missing required plug-in org.eclipse.ui_0.0.0.
!MESSAGE Missing required plug-in org.eclipse.ui.ide_0.0.0.
!MESSAGE Missing required plug-in org.eclipse.xsd_0.0.0.
!MESSAGE Missing required plug-in org.eclipse.core.resources_0.0.0.
These plugins exist in eclipse/plugins, but they have 3.x version #'s
attached.
Question: where is it getting 0.0.0? How do I get past this?
Re: Troubles with eclipse.buildScript and versions of dependent plugins [message #281501 is a reply to message #281348] Mon, 21 February 2005 00:58 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
To use this mechanism makes sure your plugins are in a plugins folder
and features in a feature folder.
> </target>
> </project>
> <plugin
> id = "runtime"
> version = "1.0.0"
> <requires>
> </requires>
> <runtime>
> <export name="*"/>
> </library>
> </library>
> </runtime>
> <package uri = "http://www..com//2005/runtime" class =
> </extension>
> <package uri = "http:////runtime/adapter.ecore" class =
> </extension>
> </plugin>
> and I get this:
> attached.
Re: Troubles with eclipse.buildScript and versions of dependent plugins [message #281543 is a reply to message #281501] Mon, 21 February 2005 16:57 Go to previous messageGo to next message
Thanks for responding.
The required plugins are in c:\eclipse\plugins (with the 3.x version
suffixes. RUNTIME is a plugin project for which I am trying to generate a
build script. Are you saying that I need to put the RUNTIME project files
in a plugins directory?
>> <?xml version="1.0" encoding="UTF-8"?>
>> </target>
>> </project>
>> <plugin
>> id = "runtime"
>> version = "1.0.0"
>> <requires>
>> </requires>
>> <runtime>
>> <export name="*"/>
>> </library>
>> </library>
>> </runtime>
>> </extension>
>> </extension>
>> </plugin>
>> and I get this:
>> attached.
Re: Troubles with eclipse.buildScript and versions of dependent plugins [message #1783583 is a reply to message #281543] Wed, 14 March 2018 11:36 Go to previous messageGo to next message
Shivendra Prakash Shukla is currently offline Shivendra Prakash ShuklaFriend
I am also getting the same issue, but I make sure my plugins are in a plugins folder and features in a feature folder.
[java] [eclipse.buildScript] Bundle org.eclipse.emf.codegen.ecore.ui:
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.emf.codegen.ecore_[2.14.0,3.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.emf.common.ui:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.emf.common.ui_2.13.0.v20171102-0636
Re: Troubles with eclipse.buildScript and versions of dependent plugins [message #1783587 is a reply to message #1783583] Wed, 14 March 2018 12:06 Go to previous messageGo to next message
This thread is very very old. No one at Eclipse uses PDE build anymore. Better use to Tycho to do production builds. Likely you've installed using the installer and this script is pointing into the bundle pool where there are likely by now many versions of each bundle.
Ed Merks
Re: Troubles with eclipse.buildScript and versions of dependent plugins [message #1783631 is a reply to message #1783587] Wed, 14 March 2018 17:28 Go to previous messageGo to next message
Hi Ed,
Yes, I understand it's very old post, This type issue I am facing eclipse 4.7.2 and I verified all plugins are available, but still, i am facing this issue. Please give some suggestion. Thanks in Advance...
Re: Troubles with eclipse.buildScript and versions of dependent plugins [message #1783650 is a reply to message #1783631] Thu, 15 March 2018 05:34 Go to previous message
I'd suggest not trying to use Ant to do your build. This is Eclipse projects generally do builds: https://wiki.eclipse.org/CBI You could look at how EMF itself has such a build: https://ci.eclipse.org/emf/ and can reproduce that build locally, as described on that page, to try to apply the same concepts to your project.
Ed Merks
Previous Topic:Fuzzy letters, small icons
Next Topic:Getting java.lang.RuntimeException: No application id has been found. on running product file
Current Time: Mon Aug 10 16:24:48 GMT 2020
Powered by FUDForum. Page generated in 0.13641 seconds
