Re: Nothing appears in the palette or Design View after RHEL 6 update [message #1524994 is a reply to message #1524912] |
Tue, 23 December 2014 19:58 |
Eric Clayberg Messages: 979 Registered: July 2009 Location: Boston, MA |
If it is appearing in multiple window managers, it is likely a problem with one of the updated OS libraries included with that update. A video driver bug could also be the cause and would affect multiple window managers as well. I doubt the problem lies in any Eclipse or SWT code as you stated it worked fine prior to the OS update. Something is disabling off screen rendering, so you are getting a blank image. I have seen "optimizations" like that done in Linux updates in the past and then seem them backed out in the very next update. Each new generation of developers hacking on Linux seems to introduce the same bug and then fix it later. I have seen this happen several times over the last ten years or so. Unfortunately, Linux is the Wild West of operating systems, and you are guaranteed virtually no forward, backward, or sideways (between distros) compatibility.
[Updated on: Tue, 23 December 2014 21:33] Report message to a moderator
FUDForum. Page generated in 0.05021 seconds
