Home » Eclipse Projects » BPMN 2.0 Modeler » Local/Global variables(Local/Global variables)
Local/Global variables [message #1522571] Mon, 22 December 2014 11:49 Go to next message
Andrea Carpineti is currently offline Andrea CarpinetiFriend
I'm bit confused about global variables showed in the Properties tab (see attached screenshot). I saw they are introduced as extensionElement in the source .xml file and infact the BPMN 2.0 specification never refers global vars.
How should be used in the BPMN modeler plugin?
What the difference with the local vars?
many tks,
ac
Re: Local/Global variables [message #1533981 is a reply to message #1522571] Sun, 28 December 2014 22:54 Go to previous messageGo to next message
Robert Brodt is currently offline Robert BrodtFriend
Global Variables are actually a jBPM extension and not defined by the BPMN 2.0 specification. The so-called "local variables" are BPMN 2.0 Property elements.
Re: Local/Global variables [message #1551067 is a reply to message #1533981] Wed, 07 January 2015 11:42 Go to previous messageGo to next message
Thanks Robert...
that's what I told you Smile
Any hint on how should be used?
many thanks
Re: Local/Global variables [message #1551242 is a reply to message #1551067] Wed, 07 January 2015 13:57 Go to previous messageGo to next message
Here, let me google that for you...
Re: Local/Global variables [message #1565457 is a reply to message #1551242] Thu, 15 January 2015 09:38 Go to previous messageGo to next message
Smile great
I thought the global vars was an extension introduced by the jBPM plugin (BPMN2 Modeler): that's why I'm asking here. My fault.
many thanks Robert
Re: Local/Global variables [message #1566137 is a reply to message #1565457] Thu, 15 January 2015 17:53 Go to previous message
Well, yes and no...Global Variables are a concept only defined by the jBPM engine. The BPMN2 Modeler in its "generic" form only supports the BPMN 2.0 specification and does not know about these Global Variable extensions. The jBPM editor plugin which extends BPMN2 Modeler however, DOES know about Global Variables and contributes these (and a whole bunch of other stuff) as BPMN 2.0 language extensions. Hope it's starting to make more sense now Wink
Previous Topic:Error when loading process with custom extensionElements
Next Topic:Luna update repository
Current Time: Sun Dec 15 20:22:44 GMT 2019
Powered by FUDForum. Page generated in 0.02223 seconds
