Home » Newcomers » Newcomers » mingw32-make: *** No rule to make target –f'. Stop.
mingw32-make: *** No rule to make target –f'. Stop. [message #27619] Wed, 16 February 2005 14:01 Go to next message
Originally posted by: micyaro.gmail.com
I have just installed eclipse 3.01, C/C++ Plugins and MinGW following the
howto from http://www.cs.umanitoba.ca/~eclipse/7-EclipseCDT.pdf.
While trying to compile the makefile I get this message in the console:
mingw32-make –f makefile all
mingw32-make: *** No rule to make target `–f'. Stop.
My makefile looks like this:
main : main.o
g++ -o main main.o -L C:/MinGW/lib/gcc-lib/mingw32/3.2.3/ -lstdc++
main.o : main.cpp
g++ -ggdb -c main.cpp
all :
${MAKE} main
clean :
-del main.o
Does somebody had similiar problems running eclipse and CDT?
Mic
Re: mingw32-make: *** No rule to make target ?f'. Stop. [message #27621 is a reply to message #27619] Wed, 16 February 2005 14:45 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
You probably cut-and-pasted the command from a browser?
In that case, the minus sign '-' you are seeing is probably a
hyphen (a different unicode character, indistinguishable for most).
Notice below how the '-' is turned into a square box.
Edit your command, delete the minus and enter it again.
Chris Laffra, http://eclipsefaq.org
"Mic" <micyaro@gmail.com> wrote in message
news:cuvjok$8e6$1@www.eclipse.org...
> mingw32-make
Re: mingw32-make: *** No rule to make target ?f'. Stop. [message #27675 is a reply to message #27621] Thu, 17 February 2005 09:27 Go to previous message
I could fix the problem but now while "Build Make Targer" i get this
message:
mingw32-make all
mingw32-make main
mingw32-make[1]: Entering directory `D:/mja/workspace/HelloWorld'
C:/MinGW/bin/../lib/gcc/mingw32/3.4.2/../../../libstdc++.a(e h_throw.o)(.text+0xfa):eh_throw.cc:
undefined reference to `_Unwind_SjLj_Resume_or_Rethrow'
collect2: ld returned 1 exit status
mingw32-make[1]: *** [main] Error 1
mingw32-make[1]: Leaving directory `D:/mja/workspace/HelloWorld'
mingw32-make: *** [all] Error 2
The googling on that case didnŽt really help..
Mic
Previous Topic:Eclipse fails to launch
Next Topic:How to make package explorer show sub package under package
Current Time: Tue Apr 16 23:12:45 GMT 2024
Powered by FUDForum. Page generated in 3.79420 seconds
