Home » Eclipse Projects » Nebula » [GanttChart] resizing the GanttSections height
[GanttChart] resizing the GanttSections height [message #1517468] Fri, 19 December 2014 14:16 Go to next message
Giovanni J is currently offline Giovanni JFriend
Hello guys as aforementioned in the topic's subject,
how can I modify a GanttSection's height?
Re: [GanttChart] resizing the GanttSections height [message #1518100 is a reply to message #1517468] Fri, 19 December 2014 23:12 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Did you read this? http://www.eclipse.org/forums/index.php/t/277366/
Re: [GanttChart] resizing the GanttSections height [message #1518101 is a reply to message #1518100] Fri, 19 December 2014 23:14 Go to previous messageGo to next message
Or this? http://git.eclipse.org/c/nebula/org.eclipse.nebula.git/plain/examples/org.eclipse.nebula.snippets/src/org/eclipse/nebula/snippets/ganttchart/GanttSectionExample.java
Re: [GanttChart] resizing the GanttSections height [message #1522328 is a reply to message #1518101] Mon, 22 December 2014 08:38 Go to previous messageGo to next message
Yes but it didn't help so much.
I already have all the events on a single line, now only want to shrink the standard Section's height.
[Updated on: Mon, 22 December 2014 09:36]
Report message to a moderator
Re: [GanttChart] resizing the GanttSections height [message #1523391 is a reply to message #1522328] Mon, 22 December 2014 22:33 Go to previous messageGo to next message
Hi Gio,
Please file a bug. If you would like to take a stab at a possible solution then this would be great.
Thanks for using Gantt,
Wim
Re: [GanttChart] resizing the GanttSections height [message #1536432 is a reply to message #1523391] Tue, 30 December 2014 07:44 Go to previous message
Dirk Fauth is currently offline Dirk FauthFriend
Do you override getMinimumSectionHeight() in your settings? The section height should only increase in case the calculated height is smaller than the minimum.
Previous Topic:[GanttChart] refreshing composite
Next Topic:Remove trace from XYGraph
Current Time: Sun Jan 24 07:07:37 GMT 2021
Powered by FUDForum. Page generated in 0.01586 seconds
