Home » Modeling » EMF » One EClass for Two Ecore models
One EClass for Two Ecore models [message #1516091] Thu, 18 December 2014 16:52 Go to next message
Vinicius Pereira is currently offline Vinicius PereiraFriend
Member
Hi everyone,
I have two ecore models (M1 and M2) and I want to have the same EClass in both models.
M1 and M2 are in the same project and folder. In M1 I have an EClass called Mapping. The same EClass exists in M2.
Is there a way of "link" Mapping in both models? I need that Eclipse understand that it is the same class. Because when I generate code from M2 after M1 it always overwrite the previous.
thanks
Re: One EClass for Two Ecore models [message #1516118 is a reply to message #1516091] Thu, 18 December 2014 17:19 Go to previous messageGo to next message
Vinicius,
Comments below.
On 18/12/2014 5:52 PM, Vinicius Pereira wrote:
> Hi everyone,
> in both models.
That's contradictory.
The fact it's in a different model means its a different class. There's
nothing else to say.
No.
It's not so nothing will understand that.
> previous.
It should be defined in one of the models and the other should reuse
it. There are no alternatives
> thanks
Re: One EClass for Two Ecore models [message #1516221 is a reply to message #1516118] Thu, 18 December 2014 18:50 Go to previous messageGo to next message
Member
Hmmm... I did in separated models because in thought it was better to understand and have images.
For example, in a model I show how to map a formal element to an UML element using a mapping.
In the other model, I show how to create the mapping that I use above.
In my opinion, two models was better... So I just put everything in one model?
Re: One EClass for Two Ecore models [message #1517020 is a reply to message #1516221] Fri, 19 December 2014 07:42 Go to previous messageGo to next message
Vinicius,
Comments below.
There's nothing wrong with having multiple models, it's just misguided
to "I want the same thing to be in both models".
Now sure what you mean by "showing"? Are we really talking about Ecore
models? In Ecore models you define structure, you don't just "show" things.
I don't get this "show how to create" terminology.
> one model?
That's not what I said. A concept should be defined once and if you
want to reuse it, you should reuse it, not define it a second time and
then "link" it.
Re: One EClass for Two Ecore models [message #1517381 is a reply to message #1517020] Fri, 19 December 2014 13:07 Go to previous messageGo to next message
Felix Dorner is currently offline Felix DornerFriend
Maybe you just don't know how to reuse one from the other?
You open the context menu in the editor of one, and select "Load
Resource...". Here you select the other one. And whoops, you can use the
elements from that one in your model.
Re: One EClass for Two Ecore models [message #1522224 is a reply to message #1516221] Mon, 22 December 2014 07:17 Go to previous messageGo to next message
Jan Reimann is currently offline Jan ReimannFriend
Am 18.12.2014 um 19:50 schrieb Vinicius Pereira:
> model?
what you really want is one ecore model but several different kinds of
representation of this model. I assume you want to present different
views on the same model. You can definitely do that (e.g. with several
Ecore Diagrams) but the model is the only one, as Ed already said.
cheers,
Jan
Re: One EClass for Two Ecore models [message #1524847 is a reply to message #1522224] Tue, 23 December 2014 18:04 Go to previous message
Member
Jan Reimann wrote on Mon, 22 December 2014 02:17
> model?
cheers,
Jan
Thanks! Exact what I wanted!
Thanks for all replies!
Previous Topic:[CDO] ArrayStoreException on XML imported resource
Next Topic:[CDO] Customizing Repository Cloning
Current Time: Fri Jan 17 18:17:34 GMT 2020
Powered by FUDForum. Page generated in 0.02255 seconds
