Home » Eclipse Projects » Lua Development Tools » Will ldt support debug hover to inspect local vairables?
Will ldt support debug hover to inspect local vairables? [message #1510409] Sun, 14 December 2014 03:10 Go to next message
bingcong ni is currently offline bingcong niFriend
I thought it's not a hard task. And this feature is very convenient for debugging.
Though, currently I can go to window->preferences->general->keys to set a shortcut for "Inspect" command.
Re: Will ldt support debug hover to inspect local vairables? [message #1512283 is a reply to message #1510409] Mon, 15 December 2014 16:16 Go to previous messageGo to next message
Simon Bernard is currently offline Simon BernardFriend
I'm not sure it will be so easy, but I create an issue for it.
It's clearly a great feature to have.
[Updated on: Mon, 15 December 2014 16:17]
Report message to a moderator
Re: Will ldt support debug hover to inspect local vairables? [message #1513010 is a reply to message #1512283] Tue, 16 December 2014 06:26 Go to previous message
Thank you,
After tried, I find it's really not a easy job as i thought. even with decompiled source from cocos code ide which implemented this feature already...
Previous Topic:Luadoc converts some numbers to ASCII characters
Next Topic:Build failure
Current Time: Sun Sep 25 18:53:20 GMT 2022
Powered by FUDForum. Page generated in 0.01648 seconds
