Home » Eclipse Projects » Sapphire » Feedback requested on raising minimum Java version
Feedback requested on raising minimum Java version [message #1508888] Fri, 12 December 2014 20:18 Go to next message
Konstantin Komissarchik is currently offline Konstantin KomissarchikFriend
I am considering raising Sapphire's minimum supported Java version for the release 9 in the Summer of 2015.
The current minimum supported Java version is 6, last raised for the 0.7 release.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=409330
Java 6 (2006)
Dropping support for Java 6 would allow us to integrate Sapphire models with the try-with-resources feature by making Sapphire Element extend AutoCloseable.
try( Example element = Example.TYPE.instantiate() )
vs currently
final Example element = Example.TYPE.instantiate();
try
finally
    try
        element.dispose();
    catch( final Exception e ) {}
Java 7 (2011)
Dropping support for Java 7 would allow us to take advantage of multiple annotations per site improvement in Java 8 and allow us to remove the grouping annotations (@Service and @Services, @Validation and @Validations, etc.).
@Validation( rule = "${ Max >= Min }", message = "Must not be smaller than min" )
@Validation( rule = "${ Max <= 100 }", message = "Must be less than or equal to 100" )
ValueProperty PROP_MAX = new ValueProperty( TYPE, "Max" );
vs currently
@Validations
        @Validation( rule = "${ Max >= Min }", message = "Must not be smaller than min" ),
Please respond to this thread with your thoughts on what minimum Java version support you anticipate needing beyond Sapphire 9 in Summer of 2015.
Re: Feedback requested on raising minimum Java version [message #1514898 is a reply to message #1508888] Wed, 17 December 2014 17:57 Go to previous messageGo to next message
Greg Amerson is currently offline Greg AmersonFriend
Personally for our project's usage we have to stick with Java7. No java8 on the horizon at the moment. But as long as there are java7 compatible service releases in the future (aka 8.x.x) then I don't see any problem with moving the future sapphire versions to java8.
Re: Feedback requested on raising minimum Java version [message #1560931 is a reply to message #1514898] Mon, 12 January 2015 22:17 Go to previous messageGo to next message
Based on the feedback received, the minimum Java version for Sapphire 9 and beyond has been changed to Java 8. As a consequence of this change, support for Indigo, Juno and Kepler was dropped (Eclipse added Java 8 support in Luna). Sapphire 8.x will continue to support Java 6 and all Eclipse releases going back to Indigo.
Re: Feedback requested on raising minimum Java version [message #1569893 is a reply to message #1560931] Sat, 17 January 2015 19:37 Go to previous messageGo to next message
David Williams is currently offline David WilliamsFriend
<html>
<head>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type">
</head>
<div class="moz-cite-prefix">On 01/12/2015 05:17 PM, Konstantin
Komissarchik wrote:<br>
</div>
<blockquote cite="mid:m91h5j$hpv$1@xxxxxxxxe.org" type="cite">Based
<br>
</blockquote>
Can you clarify for me, Konstantin. Does this mean for Mars release,
your source will require Java 8, but will still run on Java 7? Or,
Does it even need 1.8 JRE to run? (And, I'm just academically
curious ... no impact on me ... well, if it's part of any EPP
package I guess it might indirectly. :) <br>
<br>
Thanks, <br>
<br>
</body>
</html>
Re: Feedback requested on raising minimum Java version [message #1575400 is a reply to message #1569893] Tue, 20 January 2015 20:13 Go to previous messageGo to next message
package I guess it might indirectly. Smile
Sapphire 9 (our Mars contribution) will require Java 8 to run. Sapphire is not currently included in any EPP package.
Re: Feedback requested on raising minimum Java version [message #1694252 is a reply to message #1575400] Sun, 03 May 2015 19:49 Go to previous messageGo to next message
Max Rydahl Andersen is currently offline Max Rydahl AndersenFriend
Damn. Will this still be the case ?
We were planning on starting using sapphire in Mars and still support java 7 as rest of eclipse Mars does.
Re: Feedback requested on raising minimum Java version [message #1694347 is a reply to message #1694252] Mon, 04 May 2015 15:32 Go to previous message
Yes, Sapphire 9 will require Java 8 to run, while Sapphire 8.2 will require Java 6. Multiple versions of Sapphire can be installed concurrently.
Previous Topic:Not enough space for icons in ubuntu.
Next Topic:Sapphire 9.0.0 in Mars?
Current Time: Sun Jan 24 12:26:55 GMT 2021
Powered by FUDForum. Page generated in 0.02367 seconds
