Home » Eclipse Projects » Rich Client Platform (RCP) » Icons do not get replaced
Icons do not get replaced [message #1507080] Thu, 11 December 2014 09:54 Go to next message
Ludwig Moser is currently offline Ludwig MoserFriend
i'm trying to customize the launcher by adding my icons.
the problem is that the icons do not get replaced with my custom ones. (i do build with maven/tycho)
in my product i specify the ico file for windows:
index.php/fa/20202/0/
NOTE: in the beginning Eclipse showed me a small yellow triangle with the warning that resolution x was missing (this is fixed - as you see in the screenshot)
while building i get the following Error:
Error - 7 icon(s) not replaced in ...\launcher.exe using ...\AppIcon\ico\AppIcon.ico
beside that the launcher name is correct, and Eclipse does accept everything else but the icons
what am i doing wrong?
NOTE: i attached my AppIcon.ico
  • Attachment: Correct.png
    (Size: 3.16KB, Downloaded 5731 times)
  • Attachment: AppIcon.ico
    (Size: 286.01KB, Downloaded 1069 times)
Re: Icons do not get replaced [message #1507307 is a reply to message #1507080] Thu, 11 December 2014 14:03 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Does you .ico hold all required file sizes?
Tom
Re: Icons do not get replaced [message #1507342 is a reply to message #1507307] Thu, 11 December 2014 14:40 Go to previous messageGo to next message
i created the file with GIMP, where i got 7 Layers with resolutions 16(8&32bit), 32(8&32bit),48(8&32bit), 256(32bit) and exported it with the bit settings in brackets
when opening the file with IrfanView it tells me 7pages but all with 24BBP
[Updated on: Thu, 11 December 2014 14:40]
Report message to a moderator
Re: Icons do not get replaced [message #1507683 is a reply to message #1507342] Thu, 11 December 2014 21:11 Go to previous messageGo to next message
Have you compared that to the eclipse one? What information do you get
there?
Tom
Re: Icons do not get replaced [message #1508206 is a reply to message #1507683] Fri, 12 December 2014 07:47 Go to previous messageGo to next message
ok, i checked and it seems to be the same original icon shows same values as mine.
i downloaded the eclipse.ico [1] and set it as my custom icon.
then ran the build again.
Error - 7 icon(s) not replaced in ...\launcher.exe using ...\eclipse.ico
to me it seems its not about my icon... seems more like an general problem
i thought about specifying the seperate files, but as eclipse only supports BMP this is no option (no transparency)
[1] http://git.eclipse.org/c/equinox/rt.equinox.framework.git/plain/features/org.eclipse.equinox.executable.feature/library/win32/eclipse.ico
[Updated on: Fri, 12 December 2014 07:48]
Re: Icons do not get replaced [message #1561708 is a reply to message #1508206] Tue, 13 January 2015 08:49 Go to previous messageGo to next message
Ok I checked our build to see how we do it.
The trick is fairly simple. I guess you exported previously directly
from your eclipse instance and your layout looked like this:
my.app
+ icons
+ AppIcon.ico
+ MyApp.product
and now you have
my.app
+ icons
+ AppIcon.ico
my.app.product
+ MyApp.product
and you had .product
> <win useIco="true">
> <ico path="/my.app/icons/AppIcon.ico"/>
> <bmp/>
> </win>
which is now causing the problem. To fix it you:
a) copy the icons/AppIcon.ico to my.app.product
b) modify the path in your product to be
> <win useIco="true">
> <ico path="icons/AppIcon.ico"/>
> <bmp/>
> </win>
Tom
> values as mine.
> [1]
Re: Icons do not get replaced [message #1561786 is a reply to message #1561708] Tue, 13 January 2015 09:45 Go to previous messageGo to next message
changing from absolute path (starting with /bundlename)
to relative path as you suggested, did solve the problem!
thanks!
Re: Icons do not get replaced [message #1614516 is a reply to message #1561786] Fri, 13 February 2015 09:46 Go to previous message
Jerome Naylies is currently offline Jerome NayliesFriend
Hello
I integrate this thread because I have exactly the same problem with my project and the solution proposed by Tom does not work for me Sad
My project is organize like that:
my.app
my.app.product
   >icons
      >eclipse.ico
   >myApp.product
My product file contains:
   <launcher name="myApp">
      <solaris/>
      <win useIco="true">
         <ico path="icons/eclipse.ico"/>
         <bmp/>
      </win>
   </launcher>
I have downloaded the eclipse.ico file with the gitUb link indicated by Ludwig.
With this configuration, I do not have any error message at Tycho build but my application persist not to show eclipse icon:
index.php/fa/20836/0/
Thank you for your help.
Jay
  • Attachment: iconIssue.png
    (Size: 1.46KB, Downloaded 5207 times)
Previous Topic:Modifying an Eclipse extension point
Next Topic:Tycho unable to resolve dependency
Current Time: Tue Mar 02 14:46:37 GMT 2021
Powered by FUDForum. Page generated in 0.01886 seconds
