Home » Archived » BIRT » Accessible ram usage(An error occurred while runnind birt reports on tomcat)
Accessible ram usage [message #1504959] Tue, 09 December 2014 13:17 Go to next message
This error occured when I run my report on tomcat server with javabridge.
[[o:Exception]:"java.lang.Exception: Invoke failed: [[o:RunAndRenderTask]]->run. Cause: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report. VM: 1.6.0_27@://java.sun.com/" at: #-12 org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2248) #-11 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:190) #-10 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77) #-9 sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) #-8 sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) #-7 sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) #-6 java.lang.reflect.Method.invoke(Method.java:616) #-5 php.java.bridge.JavaBridge.Invoke(JavaBridge.java:1044) #-4 php.java.bridge.Request.handleRequest(Request.java:417) #-3 php.java.bridge.Request.handleRequests(Request.java:500) #-2 php.java.bridge.http.ContextRunner.run(ContextRunner.java:145) #-1 php.java.bridge.ThreadPool$Delegate.run(ThreadPool.java:60) #0 /var/lib/tomcat6/webapps/JavaBridge/java/Java.inc(232): java_ThrowExceptionProxyFactory->getProxy(16, '@V', 'T', true) #1 /var/lib/tomcat6/webapps/JavaBridge/java/Java.inc(360): java_Arg->getResult(true) #2 /var/lib/tomcat6/webapps/JavaBridge/java/Java.inc(366): java_Client->getWrappedResult(true) #3 /var/lib/tomcat6/webapps/JavaBridge/java/Java.inc(560): java_Client->getResult() #4 /var/lib/tomcat6/webapps/JavaBridge/java/Java.inc(1752): java_Client->invokeMethod(7, 'run', Array) #5 /var/lib/tomcat6/webapps/JavaBridge/java/Java.inc(1851): java_JavaProxy->__call('run', Array) #6 /var/lib/tomcat6/webapps/JavaBridge/java/Java.inc(2003): java_AbstractJava->__call('run', Array) #7 /var/www/timesheets/v2/include/fonctions_rapports.php(287): Java->__call('run', Array) #8 /var/www/timesheets/v2/include/fonctions_rapports.php(287): java_InternalJava->run() #9 /var/www/timesheets/v2/rapports/AuditSommaireExecutifClientVert/rapportsall.php(38): Rapport->Render('html') #10 {main}]
Please help
Re: Accessible ram usage [message #1538831 is a reply to message #1504959] Wed, 31 December 2014 10:48 Go to previous message
This is all the error that you get? Does the report run fine from the designer?
Previous Topic:Prompt with 1 Hidden parameter
Next Topic:RCP Designer (and Viewer)
Current Time: Sun Apr 27 11:03:01 EDT 2025
Powered by FUDForum. Page generated in 0.04756 seconds
