Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Hidden /= Read/Only
Hidden /= Read/Only [message #27265] Fri, 27 February 2009 10:20 Go to next message
Originally posted by: krischik.users.sourceforge.net
Really a JavaME problem - and you you might have fixed it already - in
which case I congratulate you.
But just in case you did the same mistake as JavaME I like to remind you
that the hidden and read/only are two different attributes and one does
not imply the other. That is: just because a file is hidden does not
mean it is also read/only.
I say this because of the ".eclipseme" file. I like to set the hidden
attribute on all ".*" files. And I am not the only one: Mac OS X will do
the same (see chflag hidden [1]) when copying to removable or network
drives. As do some implementations of rsync.
With JavaME when .eclipseme is hidden then one can not change the device
type any more. With a very obsuce error message - first time it happened
to me I searched 3 days until I found out the hidden attribute was the
problem.
Martin
[1]
http://developer.apple.com/documentation/Darwin/Reference/Ma npages/man1/chflags.1.html
mailto://krischik@users.sourceforge.net
Ada programming at: http://ada.krischik.com
Re: Hidden /= Read/Only [message #27334 is a reply to message #27265] Fri, 27 February 2009 19:18 Go to previous message
Gustavo de Paula is currently offline Gustavo de PaulaFriend
i'm not sure if it already fix. if it isn't, can you please file a bug
against mtj in order that we can evaluate how to fix?
below is the link to do that:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=MTJ
thanks!
gep
Re: Hidden /= Read/Only [message #571769 is a reply to message #27265] Fri, 27 February 2009 19:18 Go to previous message
thanks!
gep
Previous Topic:Converting to Eclipse Mobile Tools for Java
Next Topic:Error loading devices [configuration problem]
Current Time: Tue Apr 16 16:42:45 GMT 2024
Powered by FUDForum. Page generated in 0.03016 seconds
