Shortcuts for debugging [message #273902] |
Wed, 13 October 2004 15:40 |
Originally posted by: nospam.mail.com
Hi all,
I'd like to define function keys for debugging :
F5 => Continue
F8 => Step into
F9 => Step over
Can anybody tell me what to do for that ?
A. ROY
Re: Shortcuts for debugging [message #273934 is a reply to message #273916] |
Wed, 13 October 2004 18:03 |
OK. I found it. Thanks for your help.
Le Wed, 13 Oct 2004 09:40:45 -0800, Darin Swanson
<Darin_Swanson@us.ibm.com> a écrit:
> You will need to make use of the Keys preference page.
> Window>Preferences>Workbench>Keys>Modify
> You are wanting to change the "Resume" (your continue), Step into and
> Step
> over.
> These commands are categorized under Run/Debug in the default active
> configuration.
> So for example you would set the modify page:
> Category: Run/Debug
> Key Sequence: F5
> Select the F5 assignment for debugging (was Step Into)
> Hit Add
> Remove the F8 assignment for Resume
> Repeat as needed for Step Into and Step Over
> HTH
> Darins
> "AR" <nospam@mail.com> wrote in message
> news:opsfte6bxalswvks@ar.intranet.sylob.com...
>> Hi all,
>> F5 => Continue
>> F8 => Step into
>> F9 => Step over
>> A. ROY
A. ROY
FUDForum. Page generated in 0.06126 seconds
